linking errors when using DV codec
shyaki
I tried to use the DV25 encoder, but I got the following linkage error:
dv_enc.lib(umc_dv25_video_encoder.obj) : error LNK2019: unresolved external symbol "public: __thiscall UMC::DVVideoEncoder::DVVideoEncoder(void)" (??0DVVideoEncoder@UMC@@QAE@XZ) referenced in function "public: __thiscall UMC::DV25VideoEncoder::DV25VideoEncoder(void)" (??0DV25VideoEncoder@UMC@@QAE@XZ)
I have linked dv25_enc.lib
I can use the MPEG2 encoder correctly.
Could you please give me some clue how to fix it? I attach my code in the end.
Thank you very much.
// ipp_dv25_enc_con.cpp : Defines the entry point for the console application.
#include
"stdafx.h"
#include
"ipps.h"
#include
"umc_defs.h"
#include
"umc_video_encoder.h"
#include
"umc_dv25_video_encoder.h"
#include
"umc_mpeg2_video_encoder.h"
using
namespace UMC;
int
_tmain(int argc, _TCHAR* argv[])
VideoEncoder *pCodec;
//pCodec = createMPEG2VideoEncoder();
pCodec = createDV25VideoEncoder();
if (pCodec)
delete pCodec;
pCodec = NULL;
return 0;
shyaki
I forgot to post the definition of createDV25VideoEncoder():
VideoEncoder
*createDV25VideoEncoder()
VideoEncoder* ptr = new DV25VideoEncoder;
return ptr;
shyaki
I was so suprised when I found out the reason.The DV25 codec is not finished!. I hope the intel guys will get it done soon.
Vladimir_Dudnik
Hi, DV25 codec is finished, it depends on dv_enc.lib, so you need to add this lib in your linker options
Vladimir
