linking problem on Xeon cpu
ldezsenyi
Hello!
I've triedto link my program with IPP libraries statically, but the linker had problem with relocation. I use the em64t package for linux.
Thelinker output:
g++ -shared -fPIC -Wall -D_LINUX -D_STATIC -O3 -I/opt/intel/ipp/5.1/em64t/include -I/netavis/JAVA/jdk1.6.0_01/include -I/netavis/JAVA/jdk1.6.0_01/include/linux -o libNativeMotionDetector.so motiondetector.cpp detectorctrl.cpp opregion.cpp collidetector.cpp noiseestimator.cpp propertylist.cpp -L/home/motdet/jpegcodec -L/opt/intel/ipp/5.1/em64t/lib -lippjemergedem64t -lippjmergedem64t -lippcvemergedem64t -lippcvmergedem64t -lippiemergedem64t -lippimergedem64t -lippsemergedem64t -lippsmergedem64t -lippcoreem64t -lJPEGCodec
/usr/bin/ld: /opt/intel/ipp/5.1/em64t/lib/libippimergedem64t.a(pisum16sm7as.o): relocation R_X86_64_PC32 against `m7_ownpis_Sum_16s_C1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: final link failed: Bad value
collect2: ld returned 1 exit status
make: *** [libNativeMotionDetector.so] Error 1
and the Makefile:
INCLUDE_PATH := /opt/intel/ipp/5.1/em64t/include /netavis/JAVA/jdk1.6.0_01/include
LIBRARY_PATH := /home/motdet/jpegcodec /opt/intel/ipp/5.1/em64t/lib
CC := g++
CCFLAGS := -fPIC -Wall -D_LINUX -D_STATIC -O3 $(addprefix -I,$(INCLUDE_PATH))
LDFLAGS := $(addprefix -L,$(LIBRARY_PATH))
LIBNAME := libNativeMotionDetector.so
SOURCE := motiondetector.cpp detectorctrl.cpp opregion.cpp collidetector.cpp
IPPLIB := ippjemergedem64t ippjmergedem64t ippcvemergedem64t ippcvmergedem64t
ippiemergedem64t ippimergedem64t ippsemergedem64t ippsmergedem64t
ippcoreem64t
$(LIBNAME) : $(SOURCE)
$(CC) -shared $(CCFLAGS) -o $@ $^ $(LDFLAGS) $(addprefix -l,$(IPPLIB)) -lJPEGCodec
.PHONY : clean
clean:
-rm $(LIBNAME)
The last shared library("libJPEGCodec")to link is statically linked too. This uses the
ippi,ipps,ippj,ippcc emerged and merged libraries, and make runs without any error message.
More details:
CPU: Intel Xeon CPU 5110 @ 1.60GHz
GCC: 3.4.6 (Red Hat 3.4.6-3)
System: Linux 2.6.9-42 x86_64
Have you any idea what is the cause ofthe problem?
Thanks inadvance
Laci
Vladimir_Dudnik
you ned to use the followinglinker option:
--pic-executable
Create a position independent executable. This is currently only supported on ELF platforms. Position independent executables are similar to shared libraries in that they are relocated by the dynamic linker to the virtual address the OS chooses for them (which can vary between invocations). Like normal dynamically linked executables they can be executed and symbols defined in the executable cannot be overridden by shared libraries.
Vladimir
ldezsenyi
Thanks Vladimir!
It works fine...
Laci
