median filter issue using ipp 2017 and ipp7
sumit_j_
Hi All,
I have been using Ipp7 -median filter with SetBorderMirror and my filtered image was bit matching with matlab medfilt2 (symmetric padding).
Now I am switching  to IPP2017 my observation is weird.
Ipp7 -median filter for 8U image -with SetBorderMirror  is different from Ipp2017 -median filter (api is in legacy) for same SetBorderMirror.
But Ipp7 -median filter for 8U image -with SetBorderReplicate is bit exact with IPP2017 median filter with SetBorderMirror. Also, both of them is matching with matlab medfilt2 ( zero padding).
Plz suggest what is the reason behind this any major change in enum list.
Sumit jha
_
Shaojuan_Z_Intel
How big difference is it between IPP 7 and IPP 2017 when parameter is SetBorderMirror? For floating point numbers, there could be slightly different results for different memory alignment. Please take a look at here https://software.intel.com/en-us/mkl-macos-developer-guide-obtaining-numerically-reproducible-results for more information. Thanks!
Chao_Y_Intel
Sumit,
Could you provide you test code, and submit an issue into our support page:
http://www.intel.com/supporttickets
We can have further check on this problem?
regards,
Chao
