memory leak in ipp ?
gur_1979
I was running ippiDemo.exe under Windows XP and Rational Purify. After program's exit i saw many memory leaks.
Can you explain me this situation ?!
Vladimir_Dudnik
could you please provide a little bit more information. What IPP version do you use, what functionality from ippiDemo did you try? Could you please attach sample listing from Purify report?
Remember, many automatic run-time analisers usually reports memory leaks insystem APIs, they are not related to IPP (and actually usually not a real problems).
Vladimir
gur_1979
Hi, i using ipp 5.0. Now a starting ippsDemo.exe file and stop them. ippsDemo show me default ipp16s, jaehne signal form. Again a saw many memory leaks.
Vladimir_Dudnik
Does it tells you from what module memory was leaked?
Vladimir
