missing function overloads in 9.0 Beta?
Guy_M_1
I am building a project that worked fine with IPP 8.0, but compilation fails with 9.0 Beta
1>d:\apama\src\libs\utils\apfilter.cpp(622): error C3861: 'ippiFilterRow_32f_C3R': identifier not found
1>d:\apama\src\libs\utils\apfilter.cpp(655): error C3861: 'ippiFilterColumn_32f_C3R': identifier not found
1>d:\apama\src\libs\utils\apfilter.cpp(731): error C3861: 'ippiFilter_32f_C1R': identifier not found
1>d:\apama\src\libs\utils\apfilter.cpp(1098): error C3861: 'ippiWarpAffine_32f_C1R': identifier not found
1>d:\apama\src\libs\utils\apfilter.cpp(1338): error C3861: 'ippiWarpAffine_32f_C1R': identifier not found
1>d:\apama\src\libs\utils\apfilter.cpp(1375): error C3861: 'ippiRotateCenter_8u_C1R': identifier not found
1>d:\apama\src\libs\utils\apfilter.cpp(1426): error C3861: 'ippiRotateCenter_32f_C1R': identifier not found
When I look in ippi.h, these functions are missing - but they are there in 8.0.
For example, in 8.0 there were 15 overloads of 'ippiFilterRow_xxx_xxx, there is now only one,
IPPAPI( IppStatus, ippiFilterRow_64f_C1R, ( const Ipp64f* pSrc, int srcStep,
        Ipp64f* pDst, int dstStep, IppiSize dstRoiSize, const Ipp64f* pKernel,
        int kernelSize, int xAnchor ))
Were they deprecated?
Igor_A_Intel
hi,
these functions have got new API, adapted for external threading and boarder support. Please use ippiFilterBorder - it supports now 2D mask as well as 1D (to substitute Row and Column flavors). Instead of WarpAffine please use WarpAffine<Interpolation> functions.
regards, Igor
Chao_Y_Intel
Have you got the chance to check the new APIs in the IPP 9.0 Beta?  Does it work for you?
Chao
