6845 Discussions
mpeg2decoder.exe will crash for some Video Stream!
flu
I am a new user of Intel IPP, I tried to used mpeg2decoder.exe( under .. ipp_samplevideoMPEG2-decodeBin") to play some video stream file. Some of stream files will cause this application crash. There was no crash problem whenI used VLC media player to play the same video stream files. Does anyone have any idea for this issue?
I transferred this mpeg2decoder sample code to Microsoft Visual c++ 6.0 and have same crash problem. In the call stack window it only displays below one line:
IPPVCT7! 00ae1a84()
It looks the crash happened inside IPPVCT7.dll.
Any one has any idea or suggestion please let me know. Thank You.
Vladimir_Dudnik
thanks for informing us about that issue. Could you please submit it to technical support, where it will be tracked, and you will be notified when solution will be available.
Vladimir
