mpeg4 stream decoding from memory
bendeguy
Hi!
I would like to decode mpeg4 video stream. The stream come from a camera and it is stored in the memory. After I've decoded itI will get another part of the stream from the camera. I can decode an mpeg4 avi file with the modified MJPEG sample code, but I don't know how to decode a stream from the memory. FIOReader reads from a file, but I don't know how to init datareader to read from memory. Do I have to use avisplitter or mpeg4splitter?etc.
Thanks in advance,
Bendeguy
Chao_Y_Intel
Some suggestion from our media experts:
In this case, user can avoid using splitter at all.The user just need to initialize properly the MediaData *in before call GetFrame().
Mainly he need to setup buffer and size using SetBufferPointer(Ipp8u *ptr, vm_sizet bytes) method.
For example, The applicationhas in memory decoded frame (FramePtr is pointer to it and FrameSize is the size of encoded frame)
MediaData in, out;
Ipp8u* FramePtr;
vm_sizet FrameSize;
in.SetBufferPointer(FramePtr, FrameSize);
decoder.GetFrame(&in, &out);
Chao
