mpeg4
gaara28
Hello, it's emergency. I search an example code for MPEG-4 decoder. I work with intel ipp functions. If somebody have already worked on mpeg4 with this functions, please contact me. Thank you for your help.
Samir
Vladimir_Dudnik
did you try IPP media-sample? It contains source code for several codecs, including MPEG4 video decoder and simple player application based on top of that.
Vladimir
gaara28
It is a solution which I want to test but I do not manage to obtain the source code of IPP media-sample.Thelink on the site of INTEL is missing http://www.intel.com/cd/software/products/asmo-na/eng/perflib/219967.htm#vac
I would like to know if you have this source code because I do not manage to obtain it. Thank you for your help.
Samir
sdhays
They're available through Intel Premier downloads. If you have a full or evaluation version of IPP, you should be able to login to http://premier.intel.com.
Scott
gaara28
Thank you for yourhelp I have solved my problem with your advice. Good bye
