problem about encryption and decryption
Liang_Lu
I tried to decryptthe ciphertext which was encrypted by ippsRijindael128EncryptCBC using the function AES_cbc_decrypt in openssl ,but i failed , then i encrypted the same plaintext using the two funtions respectively, the ciphertext was different, but i think it should be the same because the algorithmand the iput was the same, i confused.
thanks
Andrzej_Chrzeszczyk
Hello
Maybe the example from page 43 of our guide
http://software.intel.com/en-us/articles/ipp-crypto-guide/
will be helpful
Andrzej Chrzeszczyk
Ying_H_Intel
Hi
Could you pelase provide somecode snippet toshow the parameterdefination for two functions and functions call details?
or a entire test case will begreat.
Ying H.
Liang_Lu
This is the code snippet.
int ippTimingAES_CBC(int minLen,int maxLen)
Ipp8u *pPText = ippsMalloc_8u(maxLen);
Ipp8u *pPPText = ippsMalloc_8u(maxLen);
Ipp8u *pCText = ippsMalloc_8u(maxLen);
Ipp8u *pCCText = ippsMalloc_8u(maxLen);
if(pPText&&pPPText&&pCText&&pCCText)
Ipp8u iv[16];
Ipp8u saved_iv[16];
Ipp8u secret_key[32];
Ipp8u* pBuffer;
int pSize;
AES_KEY aes_enc;
AES_KEY aes_dec;
setRandom8u(secret_key,32);
setRandom8u(saved_iv,16);
setRandom8u(pPText,maxLen);
memcpy(pPPText,pPText,maxLen);
memcpy(iv,saved_iv,sizeof(saved_iv));
AES_set_encrypt_key(secret_key,IppsRijndaelkey128,&aes_enc);
ippsRijndael128GetSize(&pSize);
pBuffer = ippsMalloc_8u(pSize);
if(pBuffer){
ippsRijndael128Init(aes_enc.rd_key,IppsRijndaelKey128,pBuffer);
else{
ippsFree(pPText);
ippsFree(pPPText);
ippsFree(pCText);
ippsFree(pCCText);
ippsRijndael128EncryptCBC(pPText,pCText,minLen,pBuffer,iv,IppsCppaddingNONE);
AES_cbc_encrypt(pPPText,pCCText,minLen,&aes_enc,iv,1);
int main(){
ippTimingAES_CBC(256,256);
The result is that pCText is different form pCCText.
Andrzej_Chrzeszczyk
Hi
Compare the example where IPP and SSL give the same results:
//icpc -ipp=crypto diff3.cpp -lssl
#include
#include
#include
#include
#include
#include
#include
#include "ipp.h"
#include "ippcore.h"
#include
#define keylen 16
using namespace std;
int main()
int size=64;
const int blkSize = 16;
ippInit();
Ipp8u iv[16];
Ipp8u iv1[16];
Ipp8u iv2[16];
Ipp8u iv3[16];
Ipp8u key[16];
int num_threads;
int i;
int count=0;
int c_len; //ciphertext len;
int len; //plaintext len;
double costtime;
int j;
int ctxsize;
double timesum;
for (i=0; i<16; i++) /*init-vector*/
iv=rand()%10;
for (i=0;i<16;i++) /*key*/
key=rand()%10;
len=size;
c_len=len;
unsigned char *plaintext=(Ipp8u *)malloc(len);
memcpy(iv1,iv,sizeof(iv));
memcpy(iv2,iv,sizeof(iv));
memcpy(iv3,iv,sizeof(iv));
Ipp8u ciphertext[c_len];
memset(ciphertext,0,len);
for(i=0;i{
plaintext=(Ipp8u)rand()%10+'0';
printf("the plaintext is %s\n",plaintext);
//IPP
ippsRijndael128GetSize(&ctxsize);
IppsRijndael128Spec* pCtx = (IppsRijndael128Spec*)(new Ipp8u [ctxsize]);
ippsRijndael128Init(key,IppsRijndaelKey128,pCtx);
ippsRijndael128EncryptCBC(plaintext,ciphertext,len,pCtx,iv,IppsCPPaddingNONE);
Ipp8u deciph[sizeof(ciphertext)];
ippsRijndael128DecryptCBC(ciphertext, deciph, sizeof(ciphertext),pCtx,iv,IppsCPPaddingNONE);
cout<<"the IPP ciphertext:"<<<cout << "the IPP deciphered text: ";
for(i=0;i cout<;
cout<delete (Ipp8u*)pCtx;
//SSL
Ipp8u ciphertext2[c_len];
Ipp8u deciph2[sizeof(ciphertext2)];
EVP_CIPHER_CTX enc_ctx;
EVP_CIPHER *cipher=(EVP_CIPHER *)EVP_aes_128_cbc();
EVP_CIPHER_CTX_init(&enc_ctx);
EVP_EncryptInit_ex(&enc_ctx, cipher, NULL, key, iv2);
EVP_EncryptUpdate(&enc_ctx, ciphertext2, &c_len, plaintext, len);
EVP_CIPHER_CTX dec_ctx;
EVP_CIPHER_CTX_init(&dec_ctx);
EVP_DecryptInit_ex(&dec_ctx, cipher, NULL, key, iv3);
EVP_DecryptUpdate(&dec_ctx, deciph2, &c_len, ciphertext2, len);
cout<<"the SSL ciphertext:"<<<cout << "the SSL deciphered text: ";
for(i=0;i cout<;
cout<EVP_CIPHER_CTX_cleanup(&enc_ctx);
EVP_CIPHER_CTX_cleanup(&dec_ctx);
return 0;
Liang_Lu
Thank you very much.
