problems in ImageMagick
nemorino
I'm testing ipp-samples/image-codecs/ijg.
cjpeg, djpeg in utilites have no problem.
But, some problmes are happen in using ImageMagick with libjpeg.so.ipp
I have tested with convert in ImageMagick/utilities.
convert: Premature end of JPEG file 'test.jpg' @ jpeg.c/EmitMessage/226.
This problem is happen in any jpeg file.
What's wrong?
env : IPP6.1.1.042
gcc 3.4.6
Chao_Y_Intel
Nemorino,
I tried IJG sample with some version of ImageMagic. The jpeg.c file in ImageMagick need to be changed (attached). It may depend on the version of imagemagic. You can search INTEL_IJG to find what was changed to accommodate IPP sample code.
Chao
Vladimir_Dudnik
Please pay attention to how IPP is used in libjpeg. It requires custom jdatasrc.c and jdata dst.c file (usually an application part)
Vladimir
nemorino
Hmm.
I will see the files.
Chao_Y_Intel
Nemorino,
Chao
nemorino
Quoting - Chao Y (Intel)
Nemorino,
Chao
Thanks a lot!!!
The problem is solved.
