How may I register 2 images using Ippi, any ideas?
Please, anyone?
what do you mean under term "register"?
Vladimir
Register means when you have 2 adjacent images that are partially overlaped
& may have differesnt size, "zoom" and orientation.
I am sory to ask you this again, please , anyone?
Hi, sorry for delay,
so if I understood you correctly you are asking how to overlap two images? Did you look on IPPI manual, chapter 5, Image Arithmetic and Logical Operations, article Alpha Composition?
I thinkthese functions can be usedfor combining of two images.
Vladimir
I don't need to mix 2 images, here's an example whith what I need:
If I take 2 pictures with a camera that descibes the SAME objects, but the pictures are not taken form the same position, how do I stitch these 2 images together?
What you are described looks like some high-level task, which can require several operations on images. The IPP provides you set of highly optimized low-level operations/functions, which you can use as building bricks to develop anything you want. If you now exactly from what low-level operations can be developed such effect as you described you will be able to find appropriate functionality in IPP to speedup this process.
Vladimir
Topic Options
