replacement pattern in ippsRegExpReplaceInit
evanyan
I'm curious what kinds of replacement patterns IPP supports in ippsRegExpReplaceInit.
The only supported case I found besides raw string is as follows.
regex: ([AB])([CD])
src string: AC
replacement: $2$1
dist string: CA
Is there any other kinds of supported patterns? / What are the exact usages of replacement pattern?
-Evan
Igor_B_Intel1
IPP function perform matching and replacement operations with the Perl-compatible regular expression patterns. For the replacementit is:1. Simple text replacemet and2. Using of n-th matched subpattern ($1, 2,...) in any combination.
Igor S. Belyakov
Naveen_G_Intel
Nice information about Perl-compatible regular expressions - http://search.cpan.org/dist/perl/pod/perlre.pod
Naveen Gv
