6847 Discussions
requesting minimum/maximum operation on two images
andrewk88
I'm not sure whether someone has seen my request on that at Intel ?
I'd like toask foran image minimum/maximum operations which could be included in image compare operations category. These functions would compare the corresponding pixels of two input images pSrc1, pSrc2and write minimum/maximum result value to a image pDst.
Andrew
Vladimir_Dudnik
Hi Andrew,
we take attention to all feature requests we got, that's for sure! The best way for you is to submit your request through premier.intel.com if you are registered IPP user. It will fall into our data base where it will be tracked and reviewed on a regular base. But before doing that could you please to look through similar requests on this forum, may be you can find some solution even now:
Vladimir
andrewk88
Thanks Vladimir,
I believe your first link references exactly my request.
Andrew
Vladimir_Dudnik
Great, will you submit your request on premier?
Vladimir
andrewk88
Done !
