6847 Discussions
require some help about ipp video coding function
mshoaib_amin
Hello
I have called the function
ippiFilterDeblocking_HorEdge_MPEG4_8u_I(DecDec->image_ref->y, 176,8,2,6);
with the parameters as specified.
It is a deblocking filter but it did not removed the blocks from video.
I have followed the standard procedure function is called but results are there
plz tell me whether i should call some suportting or intialization functions before calling the function.
or i have correctly used the function.
Is the function is coded correctly or there are some bugs in its functionallity in ipp.
Shoaib
Vladimir_Dudnik
could you please tell us what version of IPP do you use and on which platform?
Vladimir
