sing of 32 float
needle__brosh
I need to get the sign value of each element in a vector.
is there a simple way to do so.
exp:
input: (32float)  1.26 0 63.54 -8.3 -1.2 1.6 5 -9 ....
output:   1    1  1   -1 -1 1 1 -1
thanks
Chao_Y_Intel
Can you check the ippsThreshold_LTValGTVal  function?
Chao
Zhen_Z_Intel
Dear customer,
You could use IPP threshold_LT & GT function, for instance:
ippsThreshold_LT_32s(pSrc, pDst, len, -1); //replace all value with -1, if <-1
ippsThreshold_GT_32s(pSrc, pDst, len, 1); //otherwise set to 1
Hope it would be useful to you.
Fiona
Igor_A_Intel
another, may be the fastest, method is to use ippsRShiftC functions - just cast pointers as (Ipp32s*) and shift on 31:
IPPAPI(IppStatus, ippsRShiftC_32s,   (const Ipp32s* pSrc, int val, Ipp32s* pDst,    int len))
and then in-place ippsOrC with 1 (cast pointers as Ipp32u):
IPPAPI(IppStatus, ippsOrC_32u_I, (                    Ipp32u val, Ipp32u* pSrcDst, int len))
regards, Igor
