static link ippsFilterNoise_RTA problem.
Rebecca_Chang1
Dear all
Did any one suffer from static link ippsFilterNoise_RTA problem??
Other IppsFilterNoise_xxx functions are all ok for statick link, but not for ippsFilterNoise_RTA_32f_I nor ippsfilterNoise_RTA_32f
any idea??
enviorment:
IPP version : 6.1.5 (ia 32)
Running platform: Windows XP 32
Rebecca
Ying_H_Intel
DearRebecca,
What is the problem you are seeing regard the function?
Ying H.
Ying_H_Intel
DearRebecca,
Ying H.
Rebecca_Chang1
I link ippsxx.libs into my project, a windows kernel driver.
the driverfail to be load if ippsfilterNoise_RTA is used.
if comment ippsfilterNoise_RTA out , the driver is loaded perfectly.
Rebecca_Chang1
Link libs 6.1.5
have called ippStaticInit(); before any ipp function call.
#IPP Static link
$(IPP_LIB_PATH)\ippsemerged.lib \
$(IPP_LIB_PATH)\ippscemerged.lib\
$(IPP_LIB_PATH)\ippsmerged.lib \
$(IPP_LIB_PATH)\ippscmerged.lib \
$(IPP_LIB_PATH)\ippcorel.lib
Rebecca_Chang1
My bad...
It works fine on Vista and later.
Seems the RTA function needs MS codec support. I guess that is why my driver canb't be load on Windows XP.
