technical support
jackson_multicore
I need answer for the following question
1.which linux distribution is suitable for ipp6.0?
2.how to link compile and execute the c and java codeusing ipp in fedore 8?
3.what is the procedure to call ipp funtion with in openmp?
4.while i compiling the c code using ipp i received the error message sharedlib cannot load,how to recover from the error?
Vladimir_Dudnik
you may find the list of supported operating systems in IPP release notes documents which is part of your IPP installation. We also provide a code sample package where you can see how to compile and link your program with IPP. Some samples use OpenMP threading on top of IPP so you may see how to use IPP functions in that way.
Vladimir
