the performance of IPP
langfox
Hello, guys.
I'm new to IPP and not sure if I got anything wrong with my code,
but the performace with IPP is lower(by comparing the value of cycle1
 and cycle2). Please give me some suggestion.
VOID InitSinTable(VOID)
INT i;
FLOAT theta;
FLOAT thea[SINTABLESIZE], sintable[SINTABLESIZE];
Ipp64u start, end, cycle1, cycle2;
start = ippGetCpuClocks();
for (i = 0; i < SINTABLESIZE; ++i)
theta = (FLOAT)i/TWOPISCALE;
sintable = (FLOAT)sin(theta);
 end = ippGetCpuClocks();
 cycle1 = end - start;
thea = (FLOAT)i/TWOPISCALE;
ippsSin_32f_A11(thea, sintable, SINTABLESIZE);
 cycle2 = end - start;
Vladimir_Dudnik
to investigate your issue we need to know some additional information, like what IPP version do you use, on what platform and OS.
Vladimir
langfox
well, it's P4 2.8G and 1GB memory, with IPP 5.1 on Windows XP SP2 system. I also tried other functions( for example,strcmp() vs ippsCompare_8u() ), the performance of IPP is always lower than C code. I don't know why... :(
Nikita_A_Intel
I suspect you link IPP statically. In this case you should initialize the dispatcher (e.g.call ippStaticInit()onceat the program beginning).
Please tell me if it helps.
Nikita
PS: Here are the lines from the manual:
Before calling any Intel IPP functions, initialize the static dispatcher by calling ippStaticInit , which will perform the complete dispatching process. Without calling this function, you will run 'px' code libraries instead of the optimized version of the code.
langfox
Thanks, it gets better.
By the way, I thought the IPP was linked dynamicly. I included ipp.h, commented lib in stublib directory. Am I wrong?
Nikita_A_Intel
Let me refer you to the page in the manual because I'm not sure what you did:
http://www.intel.com/support/performancetools/libraries/ipp/sb/CS-021491.htm
Nikita
