i make a tested pcm file(8khz,stereo,16bit),but AEC_exmp maybe not work,so i want to the tested pcm file. how to make the tested pcm file?
What exactly IPP sample did you use for testing? Did you read readme file for this sample? Usually, each IPP sample contains readme file which describes usage model for it.
Vladimir
Vladimir
