Intel® MPI Library
2292 Discussions
[-1:12528]ERROR:execvp error on file: C:\Users\ASUS-pc\source\repos\Console2\Console2\x64\Debug\Console2.exe, 拒绝访问。
曲__印强
在调试mpi时出现如下问题
代码
      program main
       include 'mpif.h'
       character* (MPI_MAX_PROCESSOR_NAME) processor_name
       integer myid,numprocs,namelen,rc,ierr
       call MPI_INIT( ierr )
      call MPI_COMM_RANK( MPI_COMM_WORLD, myid, ierr )
       call MPI_COMM_SIZE( MPI_COMM_WORLD, numprocs, ierr )
       call MPI_GET_PROCESSOR_NAME(processor_name, namelen, ierr)
       write(*,10) myid,numprocs,processor_name
 10  FORMAT('Hello World! Process ',I2,' of ',I1,' on ', 20A)
       call MPI_FINALIZE(rc)
       end
结果
PrasanthD_intel
This forum is English only forum.
We have translated your query into English and this is what we have understood
The following problems occur when debugging mpi
     program main
      include 'mpif.h'
      end
[-1:12528]ERROR:execvp error on file: C:\Users\ASUS-pc\source\repos\Console2\Console2\x64\Debug\Console2.exe, Access is denied
We suspect that this error occurs when you don't have enough privileges to run the executable.
Are you the root user in your system? if not check if your account has enough privileges to launch the program on hosts.
Could you try running the executable manually without mpiexec and see if you are able to run it.
Also, try to run mpiexec with -localonly option and see if you can run the program locally.
mpiexec -localonly <Foo.exe>
Once again register your credentials with mpiexec. For more info go through the getting started guide of mpi.
mpiexec -register
Could you please provide the permissions of the file you are trying to execute and the MPI launch command you are using ?
Thanks and regards
Prasanth
PrasanthD_intel
Have you checked the permissions as we have suggested?
let us know if you are facing any issues.
Prasanth
PrasanthD_intel
We are closing thread considering your issue is resolved.
Please raise a new thread for further queries.
Prasanth
