Intel® MPI Library
2287 Discussions
BCAST error for message size greater than 2 GB
AGG
I'm using Intel Fortran 16.0.1 and Intel MPI 5.1.3 and I'm getting an error with bcast as follows:
Fatal error in PMPI_Bcast: Other MPI error, error stack:
PMPI_Bcast(2231)........: MPI_Bcast(buf=0x2b460bcc0040, count=547061260, MPI_INTEGER, root=0, MPI_COMM_WORLD) failed
MPIR_Bcast_impl(1798)...:
MPIR_Bcast(1826)........:
I_MPIR_Bcast_intra(2007): Failure during collective
MPIR_Bcast_intra(1592)..:
MPIR_Bcast_binomial(253): message sizes do not match across processes in the collective routine: Received -32766 but expected -2106722256
I'm broadcasting Integer array (4 byte) of size 547061260. Is there an upper limit on the message size? The bcast works fine for smaller counts.
Thanks!
James_S
Hi AGG,  please see the answer by James T. at this thread: https://software.intel.com/en-us/forums/intel-clusters-and-hpc-technology/topic/499118. Thanks.
AGG
Thank you, that worked for me as well.
