Intel® MPI Library
Binary Instrumentation - ITCPIN and OpenMPI
Nitin_G
I am getting following error message while I am trying to do binary instrumentation using itcpin.
Error : E:Function RTN_FindByName called without holding lock. Call PIN_LockClient()/PIN_UnlockClient()
Command used :  mpirun -np 12 itcpin --verbose on --run --profile on --mpi /usr/lib64/openmpi/1.4-gcc/lib/libmpi.so --insert libVT <exe>
Nitin G.
James_T_Intel
Hi Nitin,
The Intel® Trace Collector is very likely not compatible with OpenMPI.  If you want to check compatibility, you can compile the provided file examples/mpiconstants.c with OpenMPI and compare the values with those provided in the Intel® Trace Collector Reference Guide, Chapter 1.2.  If any values do not match, then the two are incompatible.
Sincerely,
James Tullos
Technical Consulting Engineer
Intel® Cluster Tools
Nitin_G
Hi James,
I already checked the compatibility and the values from mpicontastans.c results completely differ with ITAC Reference guide Chapter 1.2.
Problem is I dont have the source code and the binaries are already compiled with openmpi. Is there any other way?
Nitin Gavhane
James_T_Intel
Hi Nitin,
Not using the Intel® Trace Analyzer and Collector.  I would recommend contacting the vendor of the program you are trying to instrument and ask them to either provide the source code or recompile it using the Intel® MPI Library or MPICH instead of OpenMPI.
Sincerely,
James Tullos
