Intel® MPI Library
2285 Discussions
Bug: I_MPI_VERSION vanished into 2019 release and different than MPI_Get_library_version
EricChamberland
I just noticed that the mpi.h file included with 2019 release is missing any #define that helps to detect the mpi flavor used like former I_MPI_VERSION #define.
The wrong thing is that, when calling the MPI_Get_library_version function, the output is:
Intel(R) MPI Library 2019 for Linux* OS
which I think, should be something like:
MPICH Version: 3.3b2
or close to...
I suggest two ways to fix this:
- Modify MPI_Get_library_version to return the mpich version string...
- Re-add the I_MPI_VERSION or any #define, to detect at compile-time that "Intel MPI" is used.
Eric
James_T_Intel
I have escalated this to our engineering team.
dsi-intel_d_
Does that means there is no way to know, at compile time, if we are using Intel MPI and if yes, which version ?
What is the recommanded way to work around Intel MPI's bug ?
EricChamberland
I fear this is right.  Worst, if your code (like our) verifies "#ifdef MPICH_VERSION", it will be a false positive!!! :/
Hope Intel team will fix this in future release... But it is hard to know if what we report here is being acted or not...
A (simple) workaround is to add to you command line what is missing, for example:
icpc -DI_MPI_VERSION="Intel(R) MPI Library 2019.0.1 for Linux* OS" ...
Eric
James_T_Intel
This will be resolved in Intel® MPI Library 2019 Update 2.
EricChamberland
Great! Thanks for the information! :)
Eric
James_T_Intel
We've had to make some adjustments to our release plans, and will be releasing this fix in 2019 Update 3 instead.
