Intel® MPI Library
Bug in intelMPI on AMD processors
MichalKrupicka
The problem occurs in pamcrash and starccm with intelmpi (2018, 2019, 2021) on AMD processor (AMD EPYC 7763 64-Core Processor, 2 sockets, 1 node has 128 cores) on SLES 15 SP4.
On SLES 15 SP3 there was one workaroud with LD_PRELOADed strtok library. But when SP4 came, it doesn’t work.
The computation hangs everytime when the count of mpi ranks is higher than 256.
ShivaniK_Intel
Thanks for posting in the Intel forums.
Could you please let us know whether you are facing a similar issue with the Intel processor?
We can only offer direct support for Intel hardware platforms that the Intel® oneAPI product supports. Intel provides instructions on how to compile oneAPI code for both CPU and a wide range of GPU accelerators.
https://intel.github.io/llvm-docs/GetStartedGuide.html
Thanks & Regards
Shivani
MichalKrupicka
Hi Shivani,
 thanks for the replay. We do not face this issue on intel processors.
Does it mean that intel mpi is not prepared for other processors than intel`s? Is intelmpi supposed to be run only on intel processors?
Thanks & regards,
Michal
ShivaniK_Intel
Could you please provide us with the sample reproducer code and steps to reproduce the issue at our end?
Thanks & Regards
Shivani
ShivaniK_Intel
Could you please provide us with the details of the interconnect used? Also please let us know which Intel MPI variables you set to change the fabric.
Thanks & Regards
Shivani
ShivaniK_Intel
As we did not hear back from you could please respond to my previous post?
Could you please let us know if this issue also happens with IMB-MPI1 benchmarks included in IMPI distribution?
$ mpirun -n 256 IMB-MPI1 sendrecv
Could you also please let us know whether you are using 256+ ranks on a single node with 128 cores or if this happens when using more than a single node?
Thanks & Regards
Shivani
ShivaniK_Intel
As we did not hear back from you could you please respond to my previous post?
Thanks & Regards
Shivani
ShivaniK_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Thanks & Regards
Shivani
