Intel® MPI Library
2284 Discussions
Bug report: Intel C++ Compiler 10.1: OpenMP running fails. (while MSCL is OK)
jiefeng_liang
I get right result at mscl, but wrong at icl.
It happens atp->vItems, where items pushed wrong.
#pragma omp parallel// this section fails in ICL!
#ifdef _OPENMP
#pragma omp for reduction(+: nPSize) nowait
for (int c = 0; c <= BlockMax; ++c)
#else
for (BlockT c = 0; c <= BlockMax; ++c)
#endif
const PieceT a = genPiece(c);
PieceStat* p = stat;
if (p != NULL)
#ifdef _OPENMP
++nPSize;
#endif
#pragma omp critical
p->vItems.push_back(c);
#ifdef _OPENMP
nPSize /= nCount;
#endif
TimP
How could this example work with nowait?
jiefeng_liang
According to the convention of OpenMP, nowait overrides the barrier implicit in a directive. Barrier synchronizes all threads in a team.
Since the outside parallel directive has an enforced barrier, the inside for directive has no necessary to use a barrier.
