Intel® MPI Library
2292 Discussions
Bug with setvars.sh in latest version (or a subscript)
L__D__Marks
New Contributor II
I downloaded and installed yesterday the latest base and HPC toolkits. I noticed today a bug in one or more of the scripts. After "source /opt/intel/oneapi/setvars.sh" (using --force does not matter), I am getting for "echo $1 ; echo $2 ; echo $9" (or similar)
advisor=latest
ccl=latest
dpl=latest
In other words the values that would be printed out are being exported into my environment, which is obviously not what I want!
L__D__Marks
New Contributor II
I did not respond since he clearly did not believe anything that I was reporting.
I looked more carefully at the setvars.sh script, and it is a classic example of a "Greedy Algorithm", Quoting from https://en.wikipedia.org/wiki/Greedy_algorithm (similar can be found elsewhere):
"A greedy algorithm is any algorithm that follows the problem-solving heuristic of making the locally optimal choice at each stage"
Greed can be good, but often also bad. As an illustration, suppose you want a total of 41 cents from a combination of 25, 10 and 4 cent coins. The Greedy approach is to reduce this as much as possible with 25 cents, so we take one leaving 16 cents more needed. Next, we reduce this as much as possible with a 10 cent coin – leaving 6. Then we can only use a single 4 cent; oops, we can only make 39 cents!
The different versions of the setvars.sh do not have date or release number information (bad practice!), but quoting from one:
# Convert a list of '\n' terminated strings into a format that can be moved
# into the positional arguments array ($@) using the eval "set -- $array_var"
This is classic greedy coding, converting arguments into the general $1 $2 etc variables for local convenience, ignoring the possible wider implications of this. Rather than using global variables that might be used for something else, good coding is to use local variables which are not conflicting with anything else.
My patch for what I consider to be poor coding is to myself save then restore the variables that the Intel code should not be using, i.e.
var="$@"
source /opt/intel/oneapi/setvars.sh ...
eval set -- $var
PaulF_IntelCorp
@L__D__Marks  -- sorry the attached file was rejected by the forum. The changes to this file:
/opt/intel/oneapi/intelpython/latest/env/vars.sh
are very simple. Insert the following two lines of code in the locations specified:
echo "LINENO: ${LINENO}"
echo "$@"
Please add those two lines of code into the `intelpython/env/vars.sh` file, as shown below. Several lines of code above and below the insertion point are shown for reference.
At approximately line 16:
# code at the end of this file for more help.
echo "$@"
# Get absolute path to this script.
# Uses `readlink` to remove links and `pwd -P` to turn into an absolute path.
At approximately line 201:
  return 255 2>/dev/null || exit 255
fi
echo "$@"
SCRIPTPATH=$(get_script_path "${vars_script_name:-}")
ROOTPATH=$(dirname -- "${SCRIPTPATH}")
At approximately line 228:
fi
POTENTIAL_ACTIVATE_PATH="$ROOTPATH/../../$MAINENV/$PYVER/bin/activate"
echo "$@"
# Setup conda environment env vars so the command prompt gets the correct "(env)" string
if [ "${vars_script_name}" = "${CURRENTENV}/latest/env/vars.sh" ] ; then
At approximately line 312:
    fi
fi
echo "$@"
unset OVERWRITE_CONDA_DEFAULT_ENV
unset SCRIPTPATH
Then please paste the output generated by running the `setvars.sh` script.
ShivaniK_Intel
Could you please follow the above steps provided by @PaulF_IntelCorp  and provide us with the output generated by running the `setvars.sh` script?
Thanks & Regards
Shivani
ShivaniK_Intel
As we didn't hear back from you, Could you please let us know whether your issue is resolved or not? If not, Could you please follow the above steps provided by @PaulF_IntelCorp  and provide us with the output generated by running the `setvars.sh` script?
Thanks & Regards
Shivani
L__D__Marks
New Contributor II
var="$@"
eval set -- $var
ShivaniK_Intel
Could you please confirm the version of Intel oneAPI you have been using?
Thanks & Regards
Shivani
ShivaniK_Intel
I would like to share a few observations with you.
Method 1:
Step1:
When I source the setvars.sh script of Intel oneAPI 2022.3 and
I am getting nothing
Step2:
Later I am forcing the setvars.sh script of Intel onaeAPI 2022.3 and
Method2:
When I follow the same method1 with Intel oneAPI 2022.2 and
In Step1 I am getting nothing
But in Step2 I am getting
advisor=latest
ccl=latest
dpcpp-ct=latest
As we are unable to reproduce the issue with the latest version(2022.3). Could you please confirm the Intel oneAPI version you have been using?
Thanks & Regards
Shivani
L__D__Marks
New Contributor II
Since the setvars.sh script has no release information in it, I have no idea what version I am using. It could be any from 2020 to 2023.
I previously marked my patch as the solution. Sorry, but I have better things to do since it has taken more than two months for you to acknowledge that I might be right.
ShivaniK_Intel
>>>"Since the setvars.sh script has no release information in it, I have no idea what version I am using. It could be any from 2020 to 2023".
Could you please check any of the compiler versions in the Intel oneAPI base toolkit and HPC toolkit to know the version you have been using?
Example:
dpcpp --version
icx --version
As the issue is resolved could you please confirm whether we can close this thread?
Thanks & Regards
Shivani
L__D__Marks
New Contributor II
Sorry, but your suggestion is not useful. As you know, multiple compiler etc versions can exist in the same directory, all sourced by the same setvars.sh script and under the control of the configuration file. There is no connection between them.
The setvars.sh script should have date and version information.
So long as you don't mark this as something you have solved, you can close it. (I resolved it by patching around your problem.)
ShivaniK_Intel
There is a file that contains the current version of the installed oneAPI tools.
The file is located in:
$ONEAPI_ROOT/dev-utilities/latest/bin/version.txt
The content of that file will match the version of the setvars.sh script.
Thanks & Regards
Shivani
L__D__Marks
New Contributor II
It will iff just a single version has been installed. However, if multiple have and some have been uninstalled there is little reason it should match.
ShivaniK_Intel
Could you please let us know whether do you have multiple versions of Intel oneAPI?
If yes, could you please let us know how do you source the Intel oneAPI environment?
Thanks & Regards
Shivani
ShivaniK_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance please post a new question.
Thanks & Regards
Shivani
