Intel® MPI Library
2302 Discussions
Code hangs when variables value increases
Wee_Beng_T_
I have the latest intel mpi 5.1, together with the fortran compiler in my own ubuntu linux. I tried to run my code but it hangs. It was working fine in different clusters before.
I realised the problem lies with mpi_bcast. I wrote a very simple program:
program mpi_bcast_test
implicit none
include 'mpif.h'
integer :: no_vertices,no_surfaces,size,myid,ierr,status
integer, allocatable :: tmp_mpi_data1(:)
call MPI_INIT(ierr)
call MPI_COMM_SIZE(MPI_COMM_WORLD, size, ierr)
call MPI_COMM_RANK(MPI_COMM_WORLD, myid, ierr)
if (myid==0) then
    no_vertices = 1554
    no_surfaces = 3104
end if
call MPI_BCAST(no_surfaces,1,MPI_INTEGER,0,MPI_COMM_WORLD,ierr)
call MPI_BCAST(no_vertices,1,MPI_INTEGER,0,MPI_COMM_WORLD,ierr)
allocate (tmp_mpi_data1(3*no_surfaces+11*no_vertices+1), STAT=status)
tmp_mpi_data1 = 0
if (myid==0) tmp_mpi_data1 = 100
call MPI_BCAST(tmp_mpi_data1,3*no_surfaces+11*no_vertices+1,MPI_INTEGER,0,MPI_COMM_WORLD,ierr)
print *, "myid,tmp_mpi_data1(2)",myid,tmp_mpi_data1(2)
call MPI_FINALIZE(ierr)
end program mpi_bcast_test
If I run as it is, it will hang at :
But if I change the values of no_vertices and no_surfaces to small values, like 1 or 2, it works without problem.
I wonder why? Is there a bug in intel mpi 5.1 or my own problem?
James_T_Intel
No, this has not yet been corrected.
James_T_Intel
Our developers have not yet been able to reproduce this.  Can you try running with the latest (5.1 Update 3) or with our 2017 Beta version to see if you still encounter the problem?
