Intel® MPI Library
2284 Discussions
Compilation with the mpiifx of Quantum Espresso
Sergei_Kliavinek
Dear developers,
I'm trying to compile Quantum Espresso code using newer versions of the compiler inside a Docker Image (file added to the post).
As you can see, I am using the latest version of the OneAPI HPC Toolkit as the base image. However, some rather strange things happen during configuration. I get the following:
checking for mpiifx... mpiifx
checking whether we are using the GNU Fortran compiler... no
checking whether mpiifx accepts -g... yes
checking version of mpiifx... unknown, assuming gfortran
setting F90... gfortran
setting MPIF90... mpiifx
That is, for some reason it cannot detect the version of mpiifx and ifx and use them for configuration.
At the same time I can do the following:
1. Configure a file with these parameters (in a separate file)
2. Change mpiifort to mpifx in the resulting file.
And this way works. (I add the resulting file make.inc).
This raises 2 questions:
Rather theoretical - what is mpiifx in general? On the official Intel site I saw that it is a separate compiler, however on the forum I saw that it is a wrapper for mpiifort.
How can I fix the error that occurs? Maybe I need to specify the path to mpiifx explicitly somehow? It is clear that I can manually change the config file, but this is not the most convenient way.
Any information or advice would be appreciated!
P.S..
Writing posts on your forum is just impossible, it would be great if you could simplify working with it.
Sergei_Kliavinek
Thanks to the Quantum Espresso forum, I figured out what the problem is.
It turns out that the problem is in the mpiifx file itself (/opt/intel/oneapi/mpi/2021.10.0//bin/mpiifx in my case):
the last line should be like this
${TARGET_WRAPPER} -fc="${COMPILER}" $@
instead of
${TARGET_WRAPPER} -fc="${COMPILER} $@"
I made this substitution and everything worked.
It looks like you need to make a change to this file
Sergei_Kliavinek
instead of
ShivaniK_Intel
Thanks for your feedback.
This is a known issue and will be fixed in the next release.
mpiifx is just a wrapper that calls mpiifort.
Thanks & Regards
Shivani
ShivaniK_Intel
>>>"Writing posts on your forum is just impossible, it would be great if you could simplify working with it."
Could you please elaborate more on the issue you are facing while writing the posts on the forum so that it would help us to work on it?
Thanks & Regards
Shivani
ShivaniK_Intel
Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards
Shivani
