Intel® MPI Library
2293 Discussions
Compile MPI version of AMBER20 use OneAPI, mpirun -np 4 pmemd.MPI got bus error
Chunwang
I'm trying to compile AMBER20 in a docker image (Ubuntu 18.04.5 LTS, with cuda 11 toolkits) using the latest oneAPI toolkits (l_BaseKit_p_2021.2.0.2883_offline.sh, l_HPCKit_p_2021.2.0.2997_offline.sh).
compile options:
cmake .. -DCMAKE_INSTALL_PREFIX=/usr/amber20 -DCOMPILER=INTEL -DFORCE_EXTERNAL_LIBS=mkl -DMPI=TRUE -DOPENMP=FALSE -DCUDA=FALSE -DBUILD_GUI=FALSE -DINSTALL_TESTS=FALSE -DDOWNLOAD_MINICONDA=TRUE -DCHECK_UPDATES=FALSE
I can successfully compile the pmemd.MPI, but it can't properly run (mpiexec -np 2 pmemd.MPI -i press.in -p force.parm7 -c press.rst7 -ref press.rst7 -O -o test.out).
The error is the following, it seems caused by mpirun/mpiexec, not pmemd.MPI
= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= RANK 0 PID 22283 RUNNING AT beca86746e4d
= KILLED BY SIGNAL: 9 (Killed)
= RANK 1 PID 22284 RUNNING AT beca86746e4d
= KILLED BY SIGNAL: 7 (Bus error)
By the way, the compiled non-parallel version of pmemd can run properly, the compile options is:
cmake .. -DCMAKE_INSTALL_PREFIX=/usr/amber20 -DCOMPILER=INTEL -DFORCE_EXTERNAL_LIBS=mkl -DMPI=FALSE -DOPENMP=FALSE -DCUDA=FALSE -DBUILD_GUI=FALSE -DINSTALL_TESTS=FALSE -DDOWNLOAD_MINICONDA=TRUE -DCHECK_UPDATES=FALSE
I am not sure about what is wrong.  Can oneAPI be used in a docker image?
Anyone can give me an answer? Hoping for your reply. Thanks~
Chunwang
I have tried to recompile pmemd.MPI using mpi library from mpich
tar zxf mpich-3.3.1.tar.gz
cd mpich-3.3.1
./configure --prefix=/usr/mpich
make -j 8
make install
then, remove the intel mpi path in $PATH and $LD_LIBRARY_PATH, and recompile use the following options:
cmake .. -DCMAKE_INSTALL_PREFIX=/usr/amber20 -DCOMPILER=INTEL -DFORCE_EXTERNAL_LIBS=mkl -DMPI=TRUE -DOPENMP=FALSE -DCUDA=FALSE -DBUILD_GUI=FALSE -DINSTALL_TESTS=FALSE -DDOWNLOAD_MINICONDA=TRUE -DCHECK_UPDATES=FALSE -DCMAKE_PREFIX_PATH=/usr/mpich
the resulting pmemd.MPI can work properly with mpirun/mpiexec
ShivaniK_Intel
Hii,
Could you please provide us the source code link?
Also, provide the details of I_MPI_DEBUG=30,-check-mpi by executing the below command
mpiexec -np 2 -check_mpi -env I_MPI_DEBUG=30 pmemd.MPI -i press.in -p force.parm7 -c press.rst7 -ref press.rst7 -O -o test.out
Thanks & Regards
Shivani
ShivaniK_Intel
As we didn't hear back from you, Is your issue resolved? If not, please provide the details that have been asked in my previous post.
Thanks & Regards,
Shivani
Chunwang
Sorry,  I forget to login in to check the reply recently.
Currently, this issue has not been resolved. I just used oneAPI + mpich for a compromise.
source code link:
The output of the following command:
ERROR: ld.so: object 'libVTmc.so' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
[0] MPI startup(): Intel(R) MPI Library, Version 2021.2 Build 20210302 (id: f4f7c92cd)
[0] MPI startup(): Copyright (C) 2003-2021 Intel Corporation. All rights reserved.
[0] MPI startup(): library kind: release
impi_mbind_local(): mbind(p=0x7f8a98be0000, size=1073741824) error=1 "Operation not permitted"
impi_mbind_local(): mbind(p=0x7f2615ac6000, size=1073741824) error=1 "Operation not permitted"
= RANK 0 PID 40 RUNNING AT 68fa0e48402e
= RANK 1 PID 41 RUNNING AT 68fa0e48402e
Klaus-Dieter_O_Intel
Chunwang
Hi
Thanks for your reply! I tried as you said, but it seems to has no work.
I run the docker use the following command:
docker run --rm --security-opt seccomp=unconfined -it amber20_intel:latest bash
And then executed the following command:
I just got the same error:
impi_mbind_local(): mbind(p=0x7fa7dff0e000, size=1073741824) error=1 "Operation not permitted"
impi_mbind_local(): mbind(p=0x7f1b316bb000, size=1073741824) error=1 "Operation not permitted"
=   RANK 0 PID 49 RUNNING AT 7ecc1fb746c4
=   RANK 1 PID 50 RUNNING AT 7ecc1fb746c4
Presumably the issue is related to docker limitations on /dev/shm. Please try the solution described at https://www.intel.com/content/www/us/en/develop/documentation/mpi-developer-guide-linux/top/troubleshooting/problem-mpi-limitation-for-docker.html
ShivaniK_Intel
We have not heard back from you. This thread will no longer be monitored by Intel.
If you need further assistance please post a new question.
Thanks & Regards
Shivani
