Intel® MPI Library
2285 Discussions
Compiler for Intel Xeon Phi 7120 coprocessor
Jonas_D_
I have a cluster with some Intel Xeon Phi 7120P coprocessors, but it appears that OneAPI compilers no longer support this hardware.
What compiler am I supposed to use to be able to compile for these coprocessors?
ShivaniK_Intel
Thanks for posting in the Intel forums.
>>>"What compiler am I supposed to use to be able to compile for these coprocessors?"
 Intel® Xeon Phi™ customers should continue to use compilers from the Intel® oneAPI Base Toolkit and Intel® oneAPI HPC Toolkit versions 2021.2 or 2021.1.
If you want to get access and support for the older versions of the Intel oneAPI toolkits, you need to have priority support.
Please find the below link for the priority support:
https://www.intel.com/content/www/us/en/developer/get-help/priority-support.html
Thanks & Regards
Shivani
ShivaniK_Intel
As confirmed by you internally I am going ahead and closing this thread. If you need any additional information please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards
Shivani
