Intel® MPI Library
Complex Matrix alignement
unrue
Dear Intel developers,
i'm trying to do cache alignement over struct array defined as is:
[cpp]struct complex_32 {
    float32 r;
    float32 i;
typedef struct complex_32 complex32;
static complex32  **traces;
traces = (complex32 **)malloc( *num_elems * sizeof(complex32 *));
for (i = 0; i < *num_elems; i++)
    traces = (complex32 *)malloc( *num_samples * sizeof(complex32));[/cpp]
i want to align for 16 bytes. Which is the right syntax using __declspec(align(16))) ?
Actually, using _mm_malloc instead of malloc, the code crashes on forst _mm_load_ps intrinsic.
Thanks in advance for the help.
Dmitry_K_Intel2
Hi unrue,
This forum is dedicated to MPI, Clusters, HPC and so on. Usually engineers who can answer your question visit other forums.
I hope that you got an answer in other thread, so I'll not move it.
Regards!
Dmitry
