Intel® MPI Library
2285 Discussions
Double Install of Intel Cluster Studio ICS with Single User License
Oilda
I have a single user license for ICS 2011.
I intend to install ICS on a multicore machine for developping the software.
Parallel I want to install, test and run the software on my small cluster (basically just MPI is needed).
The reason for this approach is, that I do not want to keep running the whole cluster during developping.
#1: Is this kind of double install with single user license possible?
#2: From your perspective, is this approach practical?
Karl
TimP
It's entirely normal to develop and test initially on a single node or pair of nodes, either separate from or part of your larger cluster.
Dmitry_K_Intel2
Hi Karl,
If you need MPI only you can install RTO (Run-time only) version of the Intel MPI Library. This is a free of charge version and you can install it on as many nodes as you have.
Regards!
Dmitry
Oilda
Hello Dmitry, Hello TimP,
thank you very much for your answers!
I will start with a single node and lateron move to the cluster. In fact that is the way I did it before. I just felt unshure, because it`s cumbersome.
OK, this involves the next license question:
After developping the software I want to move completely to the cluster and do there some fine tuning.
Is it possible to move the license from one computer to the other?
Karl
