Intel® MPI Library
Dynamically start MPI processes
jackyjngwn
I have a master/slave type MPI program, and I'd like the master to dynamically spawn the slave processes. I tried MPI_Comm_spawn, but it seems that I could only start slave processes on nodes where mpd.py has already been started, ie., nodes specified in mpd.hosts. However, in my case, I'd like to assume that I don't know which nodes I will use when I start the program using mpirun. The nodes where the slave processes will run are determined at run-time.
I tried to use the hydra process manager in Intel 4.1, and MPI_Comm_spawn failed. Does hydra support spawning at all?
Could anyone give me some insight or advice on how to solve my problem? Thanks.
James_T_Intel
Do you have a reproducer?  I have been able to use MPI_Comm_spawn with Hydra.  Let me check on the exact method for specifying a host outside of the provided host list for launching.
Sincerely,
James Tullos
Technical Consulting Engineer
Intel® Consulting Engineer
jackyjngwn
Thanks for replying.
I am attaching the test program I've been using. I compiled them using:
                mpiicpc -o master master.cpp
                mpiicpc -o worker worker.cpp
and ran it using:
                mpirun -n 1 -env MPI_UNIVERSE_SIZE 3 ./master.
The program completed successfully with impi 4.0.2.003, but when run with impi 4.1.1.036 on the same nodes, I got the following output:
                universe_size = 8
                node1:2d9d:  dapl_cma_connect: rdma_connect ERR -1 Function not implemented
                [0:node1] unexpected DAPL connection event 0x4006 from 7
                Assertion failed in file ../../dapl_poll_rc.c at line 1679: 0
                internal ABORT - process 0
                APPLICATION TERMINATED WITH THE EXIT STRING: Interrupt (signal 2)
I tried with mpdboot & mpiexec, and got the same error. So it's not the hydra manager's fault. Do you know what is wrong? Thanks.
