Intel® MPI Library
2300 Discussions
Efficient Core Selection Slowing Down Analysis
EG4
I run distributed FEA analyses and have upgraded to an I9 13900 which has both P and E cores.
There are 8 P cores and 16 E cores. When I run my analysis, it selects CPUs no. 0,4,8,12,16,20, 24 and 28 as seen in the task manager. It is my understanding that this is a mix of P and E cores. (P cores being 0-16, E being 17-31)
Due to the nature of the analysis, the time is controlled by the slowest core. If an E core is selected, this destroys the analysis speed. My analysis speeds are currently slower than my 2017 processor I upgraded from.
How can I force my analysis to run on the P cores automatically without manually changing the affinity every time?
Apologies if this is the wrong post location.
Cheers
Ed
Sergey_K_Intel3
In Intel MPI 2021.15 and newer you can exclude the cores on heterogenous core processors you don't want your MPI application to use:
For example, to exclude the e-cores, you can do:
set I_MPI_PIN=1
set I_MPI_PIN_PROCESSOR_EXCLUDE_LIST=16-31
In the latest Intel MPI 2021.17 you can specify the cores type you want to exclude:
set I_MPI_PIN=1
set I_MPI_PIN_PROCESSOR_EXCLUDE_LIST=ecores
References:
Hope this helps.
Sergey
