Intel® MPI Library
Error executing compiler
chang90
Due to security issues, you do not have permission to run files installed on local. I want to register permissions to work with the compiler, which extension should I register to work? Or is there a way to operate without authority?
AishwaryaCV_Intel
Thank you for posting in intel communities.
Could you please let us know the OS, hardware details of the machine you are using?
Could you please provide us with the version of the Intel OneAPI Base Toolkit and HPC Toolkit you are using?
 Could you please let us know by using which compiler you are facing this issue and what are steps you are following?
And, could you also please elaborate on your issue so that we can try and investigate more at our end?
Thanks and Regards,
Aishwarya
chang90
Thank you for your answer.
The OS I use is Windows 10, and it has been updated to the latest version. I don't install OneAPI, but I only use Compiler by installing vs bulk tool and HPC toolkit. The version is 2022. If you run it because you do not have permission, Compiler will not run. Thank you.
AishwaryaCV_Intel
Could you please confirm on toolkit you downloaded is from OneAPI HPC toolkit?
Can we get more details on which compiler you are facing issue? And screenshot of error message would help us better in understanding.
Thanks And Regards,
Aishwarya
AishwaryaCV_Intel
We haven't heard back from you,Could you please provide us with the requested details?
Thanks & Regards,
Aishwarya
AishwaryaCV_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Thanks And Regards,
Aishwarya
