Intel® MPI Library
2301 Discussions
Executing MPI Exectuable on Azure Cluster
Mausolff__Zander
I am having difficulty running my MPI application across multiple nodes on a Windows cluster.
Configuration
This cluster was setup with Microsoft Azure.  It is a head node and two compute nodes with a 40 Gb/s interconnect.  Each node is running Windows Server 2016 datacenter with the 2016 HPC Pack installed.
I am launching the jobs using the Job Scheduler that comes with HPC Pack.
What I have tried
So far I have done the following:
- Configured each node with the MPI Run Time Library 2019 release 6
- The hydra process manager is started on each node, confirmed to have started on each
- I have done:
mpiexec -register
and provided the same username and password for all nodes (including head)
- Setup a shared drive that contains the executable and working directory I am trying to run ( M: )
- Turned the firewall off on each node
Results
I can launch my executable successfully on each of the nodes (from the head node).  E.g. run 2 processes on a single node.
But when I try to run 2 processes across 2 nodes the launcher hangs.  No error is reported and the job idles doing nothing.  The execution looks like:
mpiexec  -verbose  -ppn 1 -n 2 -hosts compn000,compn001 hostname M:\Test_Submit_HPC\distribution\Program.exe
Here are the launch arguments:
[mpiexec@compn000] Launch arguments: C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020.0.166\windows\mpi\intel64\bin//hydra_bstrap_proxy.exe --upstream-host compn000 --upstream-port 57643 --pgid 0 --launcher service --launcher-number 0 --base-path C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020.0.166\windows\mpi\intel64\bin/ --tree-width 16 --tree-level 1 --time-left -1 --collective-launch 1 --debug --service_port 0 --proxy-id 0 --node-id 0 --subtree-size 1 --upstream-fd 384 C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020.0.166\windows\mpi\intel64\bin//hydra_pmi_proxy.exe --usize -1 --auto-cleanup 1 --abort-signal 9
I have tried putting the program executable in the same location on each nodes respective HDs but still no luck.
PrasanthD_intel
Hi Zander,
In the mpiexec  -verbose  -ppn 1 -n 2 -hosts compn000,compn001 hostname M:\Test_Submit_HPC\distribution\Program.exe command
what does the hostname signify?
Could you provide the log info after setting environment variable  I_MPI_DEBUG=5
Prasanth
Mausolff__Zander
Hello Prasanth,
That 'hostname' might have been an artifact of my copying and pasting something incorrectly.
I just ran:
mpiexec  -verbose  -ppn 1 -n 2 -hosts compn000,compn001 -genv I_MPI_DEBUG=5 M:\Test_Submit_HPC\distribution\Program.exe
I believethe only output I get is from -verbose, which is:
[mpiexec@compn000] Launch arguments: C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020.0.166\windows\mpi\intel64\bin//hydra_bstrap_proxy.exe --upstream-host compn000 --upstream-port 59522 --pgid 0 --launcher service --launcher-number 0 --base-path C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020.0.166\windows\mpi\intel64\bin/ --tree-width 16 --tree-level 1 --time-left -1 --collective-launch 1 --debug --service_port 0 --proxy-id 0 --node-id 0 --subtree-size 1 --upstream-fd 368 C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020.0.166\windows\mpi\intel64\bin//hydra_pmi_proxy.exe --usize -1 --auto-cleanup 1 --abort-signal 9
Next, I ran (no -verbose):
mpiexec -genv I_MPI_DEBUG=5  -ppn 1 -n 2 -hosts compn000,compn001  M:\Test_Submit_HPC\distribution\Program.exe
and I there is no output on the command prompt or any log file in my working directory.
Zander
PrasanthD_intel
Hi Zander,
We are transferring your issue to the concerned team.
Please once check the installation and prerequisite steps to see if you have missed any steps.
Prasanth
Dunni_A_Intel
Hi Zander,
Would you please share the results of running:
mpiexec -validate -host compn000
and
mpiexec -validate -host compn001
from your head node?
Best,
Dunni
Michael_Intel
This issue has been resolved and we will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only
