Intel® MPI Library
2288 Discussions
Executing a BAT sript with white space in its path + passing arguments with white spaces
Diego_R_
Dear All,
We recently switched from mpich2 to intel mpi. I have problems starting a bat script when the path to the script and the argument passed to the script both contain whitespaces:
"path-To-MPI\mpiexec" -delegate -n 1 "path with spaces"\test.bat "argument with space"
Is there a solution to this problem ?
Diego
Example 1) :
J:\Users\diego>"C:\Users\diego\AppData\Local\XXX Software\MPI\impi5\mpiexec.exe" -delegate -n 1 "J:\Users\diego\abc DRuiz\test2.bat" "tu tu"
'J:\Users\diego\abc' is not recognized as an internal or external command, operable program or batch file.
2) If my argument does not contain white spaces, then it works
J:\Users\diego>"C:\Users\diego\AppData\Local\XXX Software\MPI\impi5\mpiexec.exe" -delegate -n 1 "J:\Users\diego\abc DRuiz\test2.bat" "tu-tu"
J:\Users\diego>echo LOCAL "test2.BAT" STARTED
3) If I use an executable instead of a BAT script, it also works:
J:\Users\diego>"abc DRuiz\qt2.bat
J:\Users\diego>"C:\Users\diego\AppData\Local\XXX Software\MPI\impi5\mpiexec.exe" -delegate -n 1 "J:\Users\diego\abc DRuiz\bin\abcd.exe" "tu tu"
  <***>   Software - rev 98765
Info    : Welcome diego
James_S
Hi Diego,
You have also submitted the issue via Intel Online Service Center, I have reproduced the issue and escalated it to the developers. Thanks.
Zhuowei
Diego_R_
It does not seem to work with mpiexec; Could you provide a sintax working with mpiexec ?
1) J:\Users\diego\abc DRuiz>impi5\mpiexec.exe -delegate -n 1 "J:\Users\diego\abc DRuiz\test2.bat "tu tu""
[-1:11284]ERROR:execvp error on file: J:\Users\diego\abc DRuiz\test2.bat tu, The filename, directory name, or volume label syntax is incorrect.
2) J:\Users\diego\abc DRuiz>impi5\mpiexec.exe -delegate -n 1 "J:\Users\diego\abc DRuiz\test2.bat \"tu tu\""
[-1:13644]ERROR:execvp error on file: J:\Users\diego\abc DRuiz\test2.bat "tu tu", The filename, directory name, or volume label syntax is incorrect.
3) J:\Users\diego\abc DRuiz>impi5\mpiexec.exe -delegate -n 1 ""J:\Users\diego\abc DRuiz\test2.bat" "tu tu""
[-1:9604]ERROR:execvp error on file: J:\Users\diego\abc, The filename, directory name, or volume label syntax is incorrect.
jimdempseyatthecove
Intel(R) MPI Library 2017 for Windows* Target Build Environment for Intel(R) 64
applications
Copyright (C) 2007-2016 Intel Corporation. All rights reserved.
C:\Windows\system32>cd \
C:\>md "test\diego"
C:\>md "test\diego\abc DRuiz"
C:\>echo arg1=%1, arg2=%2>"test\diego\abc DRuiz\test2.bat"
C:\>type "test\diego\abc DRuiz\test2.bat"
arg1=%1, arg2=%2
C:\>notepad "test\diego\abc DRuiz\test2.bat"
C:\>mpiexec -n 1 "C:\test\diego\abc DRuiz\test2.bat" X Y
C:\>echo arg1=X, arg2=Y
arg1=X, arg2=Y
C:\>
Note, the notepad was to edit the test2.bat file to insert the missing "echo "
Jim Dempsey
jimdempseyatthecove
Edit, added:
C:\>mpiexec -n 1 "C:\test\diego\abc DRuiz\test2.bat" "X Y" "a b"
'C:\test\diego\abc' is not recognized as an internal or external command,
So the problem is not on the program, but rather on the arguments. Let me experiment more...
Jim Dempsey
jimdempseyatthecove
Awful hack:
echo arg1=%arg1%, arg2=%arg2%
C:\>set arg1=X Y
C:\>set arg2=a b
C:\>echo arg1=X Y, arg2=a b
arg1=X Y, arg2=a b
Using environment variables to pass args, ugly as it is, may get you by for now.
Jim Dempsey
Diego_R_
I do not like the solution with environment variables for two reasons:
1) I will need to pass the environment variable to remote processes (kind of ok with -genvall or similar)
2) Each call to  mpiexec made by my application needs to set a different value to the environment variable. Therefore I can not make concurrent calls anymore* !!  (For example, we start 10 different mesh generations simultanesouly, each one relying on a mpi session ).
* Using different environment variable names is not a solution: If I have to write the script to change the variable name each time, then I also need to transmit the script to remote computers ...  Furthermore, if the script needs to be slightly different on each machine, then I have to prefetch it ... and I need to clean used environment variable names ... plus risk of environment variable name collision.
