Intel® MPI Library
2298 Discussions
How can I specify IB Adapter when using mpirun?
youn__kihang
Hello everyone,
I have one question to ask, so I'm writing a post.
I would like to choose and use one of the Infiniband adapters.
In previous versions, it could be specified as follows,
I_MPI_OFA_ADAPTER_NAME mlx5_0
That option seems to have disappeared as it has been incorporated into OFI in recent versions.
What environment variable should I set in order to use mlx5_1?
If you have any comments, please tell us.
Thank you.
PrasanthD_intel
Hi Kihang,
You can use the variable UCX_NET_DEVICES to select from available adapters.
For example: mpirun -np 2  -env UCX_NET_DEVICES=mlx5_1:1
Let us know if you face any issues.
Prasanth
youn__kihang
Here is ibstat result.
> ibstat
CA 'mlx5_0'
    CA type: MT4117
    Number of ports: 1
    Firmware version: 14.28.1002
    Port 1:
      State: Active
      Physical state: LinkUp
      Link layer: Ethernet
CA 'mlx5_1'
    CA type: MT4123
    Number of ports: 1
    Firmware version: 20.28.1002
    Port 1:
      State: Active
      Link layer: InfiniBand
CA 'mlx5_2'
    CA type: MT4117
    Number of ports: 1
    Port 1:
      State: Active
PrasanthD_intel
Hi Kihang,
Prasanth
youn__kihang
Using the environment variable you mentioned, I was able to use the adapter I wanted !!
One more thing, are there any Intel MPI options to check the name of the adapter in use?
I tried I_MPI_DEBUG=6 and I_MPI_HYBDA_DEBUG=ON, but the adapter name did not appear.
Thank you!
PrasanthD_intel
Hi Kihang,
You can set the variable UCX_LOG_LEVEL=info to check which adapter is being used.
eg:  UCX_LOG_LEVEL=info UCX_NET_DEVICES=mlx5_1:1 mpiexec.hydra -n 2 ./a.out
Let us know if you any other queries else we can close the thread.
Prasanth
youn__kihang
All questions have been resolved.
Thank you!
PrasanthD_intel
Hi Kihang,
Thanks for the confirmation.
As the issue has been resolved, we will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
Prasanth
