Intel® MPI Library
2284 Discussions
How to run an MPI program on multiple nodes (hosts) which are not joined into a domain ?
ArthurRatz
Dear Collegues,
How to run an MPI program on multiple nodes (hosts) which are not joined into a domain ? When I try to do it an MPI program doesn't run due to mpiexec utility rejects credentials on one of the two hosts.
Thanks in advance.
Cheers, Arthur.
ArthurRatz
This problem is also solved, you should have used the --impersonate key of mpiexec utility to use it without domain credentials.
ArthurRatz
Also it's recommended to join multiple nodes to domain to provide an easier administration.
ArthurRatz
It's recommended to use a shared network storage for your MPI application since there's no need to install the application on each host separately.
ArthurRatz
It's better to run your MPI program in datacenter such as Microsoft Azure or Amazon EC2 since it provides a computational cluster complete solution rather than performing a setting up and administration tasks by your own.
ArthurRatz
And also remember that you need to install Intel MPI Library on each host (node) in a cluster to parallelize your MPI application execution.
