Intel® MPI Library
How to use Intel MPI 5.0?
Zhanghong_T_
Dear all,
I noticed that Intel has release Intel MPI 5.0 and I downloaded latest version to test it. The command I used is as follows (it works with latest Intel MPI 4.1.x):
mpiexec -wdir D:\Users\tang\Debug -mapall -hosts 1 n01 1 D:\Users\tang\Debug\fem
However, the following error messages displayed:
[mpiexec@tangDELL] ..\hydra\utils\args\args.c (255): unrecognized argument mapall
[mpiexec@tangDELL] ..\hydra\utils\args\args.c (270): argument matching returned error
[mpiexec@tangDELL] parse_args (..\hydra\ui\mpich\utils.c:3279): error parsing input array
[mpiexec@tangDELL] HYD_uii_mpx_get_parameters (..\hydra\ui\mpich\utils.c:3554): unable to parse user arguments
[mpiexec@tangDELL] ..\hydra\ui\mpich\mpiexec.c (438): error parsing parameters
Is there anything I missed to use latest MPI?
Zhanghong Tang
James_T_Intel
The -mapall option is only used for SMPD managed jobs.  We do not have an equivalent option in Hydra, and mpiexec now defaults to using Hydra.  If you want to use SMPD, run mpiexec.smpd instead.
