Intel® MPI Library
2285 Discussions
Hydra boostrap: ssh vs pbsdsh (21.4)
Viet-Duc
Versions:
- Intel oneAPI HPC Toolkits 21.4
- PBS version: 2020.1.3
- OS: CentOS Linux release 7.7.1908 (Core)
I would like to echo the issue that other users are having with multi-node jobs (oneAPI HPC v21.4).
The error is as follow:
[mpiexec@node8103] check_exit_codes
(../../../../../src/pm/i_hydra/libhydra/demux/hydra_demux_poll.c:117): unable to run bstrap_proxy on node8104 (pid 65308, exit code 256
[mpiexec@node8103] Possible reasons:
[mpiexec@node8103] 1. Host is unavailable. Please check that all hosts are available.
[mpiexec@node8103] 2. Cannot launch hydra_bstrap_proxy or it crashed on one of the hosts. Make sure hydra_bstrap_proxy is available on all hosts and it has right permissions.
[mpiexec@node8103] 3. Firewall refused connection. Check that enough ports are allowed in the firewall and specify them with the I_MPI_PORT_RANGE variable.
[mpiexec@node8103] 4. pbs bootstrap cannot launch processes on remote host. You may try using -bootstrap option to select alternative launcher.
With I_MPI_HYDRA_DEBUG=1:
/apps/compiler/intel/oneapi_21.4/mpi/2021.4.0/bin//hydra_bstrap_proxy --upstream-host node8103 --upstream-port 39812 --pgid 0 --launcher pbs --launcher-number 5 --base-path /apps/compiler/intel/oneapi_21.4/mpi/2021.4.0/bin/ --tree-width 2 --tree-level 1 --time-left -1 --launch-type 2 --debug --proxy-id 0 --node-id 0 --subtree-size 1 --upstream-fd 7 /apps/compiler/intel/oneapi_21.4/mpi/2021.4.0/bin//hydra_pmi_proxy --usize -1 --auto-cleanup 1 --abort-signal 9
Here '--launcher pbs' caused the aforementioned bootstrap error. The issue can be solved by setting : I_MPI_HYDRA_BOOTSTRAP=ssh, which is the default according to documentation.
Thus:
- 2021.3: both pbsdsh and ssh works as hydra launcher
- 2021.4: only ssh works as launcher. It could be a problem with either PBS or Intel MPI
My questions are:
- Is there a minimal version requirement for PBS ?
- Will there be a performance degradation when forcing 'ssh' as launcher ?
Labels (2)
SantoshY_Intel
Could you please specify which job scheduler(Altair PBS Pro or OpenPBS) you are using?
Also, could you please provide the command you used for checking the PBS version?
Thanks & Regards,
Santosh
Viet-Duc
It is PBS Pro version.
I checked version using the following command:
$  qsub --version
pbs_version = 2020.1.3.20210315160738
SantoshY_Intel
>>"Will there be a performance degradation when forcing 'ssh' as launcher ?"
There will be no effect on performance if we change the launcher to ssh.
>>"Is there a minimal version requirement for PBS ?"
We are working on your issue internally and will get back to you soon.
Thanks & Regards,
Santosh
James_T_Intel
Please confirm if you encounter the same error with version 2021.5.
James_T_Intel
Due to lack of reply, this case is closed for Intel support. Any further discussion on this thread will be considered community only.
