Intel® MPI Library
2284 Discussions
I_MPI_AUTH_METHOD not working with IMPI 19 Update 3
Volker_J_
I moved from Intel MPI 2018 Update 4 to Intel MPI 2019 Update 3 and it seems that the new version ignores setting the user authorization method for mpirun via environment variable I_MPI_AUTH_METHOD=delegate . Setting it directly with mpiexec -delegate still works fine. Can anyone confirm that?
https://software.intel.com/en-us/mpi-developer-reference-windows-user-authorization
Thanks and kind regards,
Volker Jacht
Anatoliy_R_Intel
Thank you for finding this issue. For some reason I_MPI_AUTH_METHOD variable was not migrated to Intel MPI 2019. This variable will be available in Intel MPI 2019 Update 4.
Anatoliy.
Vaziri__Ali
I'm using update 4 (2019.4.227) on Linux and I still get:
[0] MPI startup(): I_MPI_AUTH_METHOD environment variable is not supported.
Anatoliy_R_Intel
This variable works only on Windows.
But you will still see that warning message. I will turn off it in the next release.
You can disable this warning by setting I_MPI_VAR_CHECK_SPELLING=0 variable.
Anatoliy.
