Intel® MPI Library
2302 Discussions
I can't run program on slave node
camiyu917gmail_com
I can't run program on slave node.
execute "mpirun -f ./mpd.hosts -np 2 ./testcpp"
Hello world: rank 0 of 2 running on cluster-master
Hello world: rank 1 of 2 running on cluster-master
It is just run on master
execute "sshconnectivity.exp machines.LINUX"
Node count = 2
Secure shell connectivity was established on all nodes.
See the log output listing "/tmp/sshconnectivity.user.log" for details.
Version number: $Revision: 1.18 $
Version date: $Date: 2008/10/19 04:06:21 $
the content of mpd.hosts & machines.LINUX is
cluster-master
cluster-slave1
and save in /home/user at master & slave.
but have a problem happen when I execute "mpdboot -f ./mpd.hosts -n 2"
mpdboot_cluster-master (handle_mpd_output 739): failed to ping mpd on cluster-slave1; received output={}
I can use ssh login master from slave without password, also can use ssh login slave from master without password,
and I already close firewall.
Please Help me.... Thanks...
Dmitry_K_Intel2
Hello Camiyu917,
Seems you have configured your cluster for using ssh, so I think that you cantry to add "-r ssh" to both commands?
If you need to start 1 process per host you can set I_MPI_PERHOST to 1 and checkit launching "mpirun -n 2..." - it should start 2 process on 2 different nodes.
Regards!
Dmitry
camiyu917gmail_com
Hello Camiyu917,
Regards!
Dmitry
Dmitry, thanks for your replication.
I met a another problem.
I try to execute "mpdboot -n 2 -f ./mpd.hosts -r ssh", but have this problem.
mpdboot_cluster-master (handle_mpd_output 730): Failed to establish a socket connection with cluster-slave1:33736 : (111, 'Connection refused')
mpdboot_cluster-master (handle_mpd_output 747): failed to connect to mpd on cluster-slave1
After "export I_MPI_PERHOST=1", I execute "mpirun -n 2 -f ./mpd.hosts -r ssh ./testcpp".
I get this problem
mpiexec_cluster-master (mpiexec 841): no msg recvd from mpd when expecting ack of request. Please examine the /tmp/mpd2.logfile_user log file on each node of the ring.
Thanks for your help ~ ^__^
Dmitry_K_Intel2
Camiyu917, could you send /tmp/mpd2.logfile_user files? This is very strange error.
Best wishes!
Dmitry
camiyu917gmail_com
I am execute "export I_MPI_PERHOST=1" and "mpirun -n 2 -f ./mpd.hosts -r ssh ./testcpp".
============== mpd2.logfile_user_090522.055102_15438 ================
logfile for mpd with pid 15491
cluster-master_37718 (handle_rhs_input 2145): connection with the right neighboring mpd daemon was lost; attempting to re-enter the mpd ring
cluster-master_37718 (reenter_ring 691): reenter_ring returned 0 after 1 tries
cluster-master_37718 (handle_rhs_input 2152): the daemon successfully reentered the mpd ring
thanks you~
Dmitry_K_Intel2
Hi Camiyu917,
Could you try to run `mpdboot -r ssh -f mpd.hosts -n 2 --chkuponly`
If it doesn't work it means that ssh doesn't work properly.
And try please the following commands:
`mpdboot -r ssh -f mpd.hosts -n 2`
`mpdtrace`
`mpiexec -genv I_MPI_PERHOST 1 -n 2 hostname`
`mpiexec -genv I_MPI_PERHOST 1 -n 2 ./testcpp`
`mpdallexit`
`mpirun -r ssh -f ./mpd.hosts -genv I_MPI_PERHOST 1 -n 2 ./testcpp`
Let me know the output we've seen.
And please sendme /etc/hosts as well.
Best wishes.
Dmitry
camiyu917gmail_com
Hello Dmitry:
checking cluster-slave1
there are 2 hosts up (counting local)
mpdboot_cluster-master (handle_mpd_output 730): Failed to establish a socket connection with cluster-slave1:33674 : (111, 'Connection refused')
/etc/hosts
127.0.0.1 localhost
192.168.2.150 cluster-master cluster-master
192.168.2.151 cluster-slave1 cluster-slave1
thanks for your help.
Dmitry_K_Intel2
Hi Camiyu917,
Please login to both servers and check that there is no running mpd.py. Execute 'killall -9 mpd.py' to be sure. (Existing mpd.py processes can prevent a ring creation).
Start 'mpdboot -r ssh -f mpd.hosts -n 2 --debug' (and let me know the output).
Port on your machines (33674) was closed somehow. Might be this is firewall or some other settings. Could you switch off your firewall for short period of time just to check mpi commands?
Best wishes!
Dmitry
camiyu917gmail_com
Hello Dmitry:
I hava close firewall and check no mpd.py process on master and slave1.
Then I execute "mpdboot -r ssh -f mpd.hosts -n 2 --debug" on master and slave1.
=================== execute on cluster-master =========================
debug: starting
running mpdallexit on cluster-master
debug: launch cmd= env I_MPI_JOB_TAGGED_PORT_OUTPUT=1 /opt/intel/impi/3.2.0.011/bin64/mpd.py --ncpus=1 --myhost=cluster-master -e -d -s 2
debug: mpd on cluster-master on port 45068
debug: info for running mpd: {'ip': '192.168.2.150', 'ncpus': 1, 'list_port': 45068, 'entry_port': '', 'host': 'cluster-master', 'entry_host': '', 'ifhn': ''}
debug: launch cmd= ssh -x -n cluster-slave1 'env I_MPI_JOB_TAGGED_PORT_OUTPUT=1 HOSTNAME=$HOSTNAME HOSTTYPE=$HOSTTYPE MACHTYPE=$MACHTYPE OSTYPE=$OSTYPE /opt/intel/impi/3.2.0.011/bin64/mpd.py -h cluster-master -p 45068 --ifhn=192.168.2.151 --ncpus=1 --myhost=cluster-slave1 --myip=192.168.2.151 -e -d -s 2'
debug: mpd on cluster-slave1 on port 55976
debug: info for running mpd: {'ip': '192.168.2.151', 'ncpus': 1, 'list_port': 55976, 'entry_port': 45068, 'host': 'cluster-slave1', 'entry_host': 'cluster-master', 'ifhn': '', 'pid': 11783}
=================== execute on cluster-slave1 =========================
debug: starting
running mpdallexit on cluster-slave1
debug: launch cmd= env I_MPI_JOB_TAGGED_PORT_OUTPUT=1 /opt/intel/impi/3.2.0.011/bin64/mpd.py --ncpus=1 --myhost=cluster-slave1 -e -d -s 2
debug: mpd on cluster-slave1 on port 60362
debug: info for running mpd: {'ip': '192.168.2.151', 'ncpus': 1, 'list_port': 60362, 'entry_port': '', 'host': 'cluster-slave1', 'entry_host': '', 'ifhn': ''}
debug: launch cmd= ssh -x -n cluster-master 'env I_MPI_JOB_TAGGED_PORT_OUTPUT=1 HOSTNAME=$HOSTNAME HOSTTYPE=$HOSTTYPE MACHTYPE=$MACHTYPE OSTYPE=$OSTYPE /opt/intel/impi/3.2.0.011/bin64/mpd.py -h cluster-slave1 -p 60362 --ifhn=192.168.2.150 --ncpus=1 --myhost=cluster-master --myip=192.168.2.150 -e -d -s 2'
debug: mpd on cluster-master on port 42052
debug: info for running mpd: {'ip': '192.168.2.150', 'ncpus': 1, 'list_port': 42052, 'entry_port': 60362, 'host': 'cluster-master', 'entry_host': 'cluster-slave1', 'ifhn': '', 'pid': 30178}
thank you
Best regard
John
Dmitry_K_Intel2
Hi John,
Seems you were able to start MPD ring with firewal switched off. To be sure you can run mpdtrace.
Could you try to do the same with firewall switched on. We do NOT recommend to use firewall for MPI application or configure it so that all ports will be available for internal connections.
Best wishes,
Dmitry
smtp12357
Hi
I have the same problem with command mpdboot. After execution I got the following log
[shell]Runing on the host n2114.nodes
This jobs runs on the following processors:
n2114.nodes n2114.nodes n2113.nodes n2113.nodes n2112.nodes n2112.nodes
running mpdallexit on n2114.nodes
LAUNCHED mpd on n2114.nodes via
RANNING: mpd on n2114.nodes
LAUNCHED mpd on n2113.nodes via n2114.nodes
LAUNCHED mpd on n2112.nodes via n2114.nodes
mpd_boot_n2114.nodes (handle_mpd_output 730): Failed to establish a socket connection with n2112.nodes:43606 : (111, 'Connection refused')
mpd_boot_n2114.nodes (handle_mpd_output 747): Failed to connect to mpd on n2112.nodes
[/shell]
Does anybody know how to fix this problem using only user access to cluster?
Dmitry_K_Intel2
Quoting - smtp12357
HLAUNCHED mpd on n2114.nodes via
Hi smtp12357,
Yeah, seems you have the same problem. You can start mpds but you mpds cannot open connection- it looks like ports are closed. Might be this is firewall. Could you ask sysadmin to open tcp ports for internal connections or just switch firewall off.
Best wishes,
Dmitry
smtp12357
Dmitry, Thank you for explanation.
I asked our sysadmin and he solved this problem. Now mpdboot works well
camiyu917gmail_com
Hi John,
Best wishes,
Dmitry
Hello Dmitry:
I have firewall switch on, then I sure master can user ssh login slave1 without password and slave1 can login master too.
I execute follow instruction:
-- no message
mpdtrace
cluster-master
cluster-slave1
mpdallexit
-- no message
=============== mpd2.logfile_user_090601.094125_3962 ======================
cluster-master_48124 (handle_rhs_input 2145): connection with the right neighboring mpd daemon was lost; attempting to re-enter the mpd ring
cluster-master_48124 (reenter_ring 691): reenter_ring returned 0 after 1 tries
cluster-master_48124 (handle_rhs_input 2152): the daemon successfully reentered the mpd ring
I do not know how to solve this problem...
I try execute follow instruction. I get very strange message.
-- no message
mpiexec -n 8 ./testcpp
mpiexec -n 2 ./testcpp
mpiexec -n 4 ./testcpp
Hello world: rank 0 of 4 running on cluster-master
Hello world: rank 1 of 4 running on cluster-master
Hello world: rank 2 of 4 running on cluster-master
Hello world: rank 3 of 4 running on cluster-master
Hello world: rank 0 of 8 running on cluster-master
Hello world: rank 1 of 8 running on cluster-master
Hello world: rank 2 of 8 running on cluster-master
Hello world: rank 3 of 8 running on cluster-master
Hello world: rank 4 of 8 running on cluster-master
Hello world: rank 5 of 8 running on cluster-master
Hello world: rank 6 of 8 running on cluster-master
Hello world: rank 7 of 8 running on cluster-master
The cluster-master's CPU is Intel Pentium D 925+, this CPU just have 1 core and 2 hyper-thread.
First, I execute `mpiexec -n 8` I got error message, but finall this program run on cluster-master user 8 core. Is this bug?
If you need, I can email our Teamviewer's ID and password to you.
Best Regard
John
Dmitry_K_Intel2
Hello Dmitry:
mpdallexit
-- no message
-- no message
Best Regard
John
Hi John,
Fromthe first part ofyour question it seems to me that Firewall doesn't allow to establish connetion between mpiexec and mpd. To get more info you can use --verbose switch.
Could you send log file from cluster-slave? This is the most interesting file.
Second part: mpd itself is smart enough to change anmpd-ring. And the message: "with the right neighboring mpd daemon was lost; attempting to re-enter the mpd ring" says that there will be new ring - in your case only one node has left - only your task will be executed on one node only.
You can start all processes on one node - no problem, but you'll get performance not as good as you start them in parallel.
You can write me directly dmitry.kuzmin (at) intel.com
Best wishes,
Dmitry
