Intel® MPI Library
I had a problem using InterMPI
植村文哉
Hi
I had a problem using InterMPI.
After compiling using the inter compiler and submitting the job on the supercomputer, the computation is completed immediately.
The standard output file at the end of the job is described below.
CPUinfo
Processor name: Intel Xeon Platinum 8368
node: 1
Total number of parallels: 76
elapse time: 01:00:00
(output file script)
Running on 76 processors
Initial blocks all at level 2 with a resolution 1.2500001E-04
= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= RANK 0 PID 3913454 RUNNING AT cpu0603
= KILLED BY SIGNAL: 9 (Killed)
= RANK 1 PID 3913455 RUNNING AT cpu0603
= RANK 2 PID 3913456 RUNNING AT cpu0603
= RANK 3 PID 3913457 RUNNING AT cpu0603
= RANK 4 PID 3913458 RUNNING AT cpu0603
= RANK 5 PID 3913459 RUNNING AT cpu0603
= RANK 6 PID 3913460 RUNNING AT cpu0603
= KILLED BY SIGNAL: 6 (Aborted)
= RANK 7 PID 3913461 RUNNING AT cpu0603
Barbara_P_Intel
Intel MPI questions are best answered on the HPC Toolkit Forum. I'll move this there.
VeenaJ_Intel
Thanks for posting in Intel communities!
To assist you more effectively, could you kindly provide the following details:
Operating System (OS) Details
Intel MPI version
Output of the "lscpu" command
Hardware Details
Detailed Steps for Recreating the Scenario
Your cooperation in furnishing this information will greatly aid in addressing your concerns. Thank you in advance!
Veena
VeenaJ_Intel
We have not heard back from you. Can you please provide the details requested?
Veena
VeenaJ_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Veena
