Intel® MPI Library
ICS Installation problems
zuch
I have experienced some problems installing ics_2011.0.013
1. installer does not copy compilers and mkl libraries to the nodes (no problem on the master node)
2.iccvars.sh refers to non existing directories
e.g."/opt/intel/ics/2011.0.013/fc/bin/ifortvars.sh"suppose to load fortran compiler however the new location for the compiler is "compilerpro orcomposerxe" but not "fc"
I wonder if the installer has been updated and if other issues arise if I fix them manually.
Ideally I would like to be able to load ics withmodules environment. Is there any fast solution except rewriting this scripts manually to modulefiles or tracing changes to ENV.
Dmitry_K_Intel2
Hi zuch,
Could you please submit a tracker at Premier Support against "Intel Fortran Compiler for Linux" and attach your installation log file?
Regards!
Dmitry
zuch
Hi Dmitry,
Thank you for your reply.
I will forward it to system administrator since he has Premier Support accountbut he does not do Linux clusters.
Regards, Z.
