Intel® MPI Library
IMPI run error
ye__xiang
Dear All,
    I compiled VASP package with IMPI succcessfully, when I run the program, the program stops with
some MPI errors listed as below.  Could anybody tell me how to fix it. Thanks!
Xiang YE
[0] MPI startup(): Intel(R) MPI Library, Version 2017 Update 4  Build 20170817 (id: 17752)
[0] MPI startup(): Copyright (C) 2003-2017 Intel Corporation.  All rights reserved.
[0] MPI startup(): Multi-threaded optimized library
[3] MPI startup(): Found 1 IB devices
[5] MPI startup(): Found 1 IB devices
[24] MPI startup(): Found 1 IB devices
[15] MPI startup(): Found 1 IB devices
[25] MPI startup(): Found 1 IB devices
[14] MPI startup(): Found 1 IB devices
[26] MPI startup(): Found 1 IB devices
[9] MPI startup(): Found 1 IB devices
[16] MPI startup(): Found 1 IB devices
[27] MPI startup(): Found 1 IB devices
[7] MPI startup(): Found 1 IB devices
[1] MPI startup(): Found 1 IB devices
[17] MPI startup(): Found 1 IB devices
[18] MPI startup(): Found 1 IB devices
[8] MPI startup(): Found 1 IB devices
[10] MPI startup(): Found 1 IB devices
[19] MPI startup(): Found 1 IB devices
[20] MPI startup(): Found 1 IB devices
[0] MPI startup(): Found 1 IB devices
[11] MPI startup(): Found 1 IB devices
[21] MPI startup(): Found 1 IB devices
[2] MPI startup(): Found 1 IB devices
[22] MPI startup(): Found 1 IB devices
[13] MPI startup(): Found 1 IB devices
[12] MPI startup(): Found 1 IB devices
[23] MPI startup(): Found 1 IB devices
[4] MPI startup(): Found 1 IB devices
[6] MPI startup(): Found 1 IB devices
[0] MPI startup(): Open 0 IB device: mlx5_0
[11] MPI startup(): Open 0 IB device: mlx5_0
[20] MPI startup(): Open 0 IB device: mlx5_0
[2] MPI startup(): Open 0 IB device: mlx5_0
[21] MPI startup(): Open 0 IB device: mlx5_0
[9] MPI startup(): Open 0 IB device: mlx5_0
[3] MPI startup(): Open 0 IB device: mlx5_0
[22] MPI startup(): Open 0 IB device: mlx5_0
[25] MPI startup(): Open 0 IB device: mlx5_0
[1] MPI startup(): Open 0 IB device: mlx5_0
[23] MPI startup(): Open 0 IB device: mlx5_0
[13] MPI startup(): Open 0 IB device: mlx5_0
[4] MPI startup(): Open 0 IB device: mlx5_0
[10] MPI startup(): Open 0 IB device: mlx5_0
[15] MPI startup(): Open 0 IB device: mlx5_0
[26] MPI startup(): Open 0 IB device: mlx5_0
[14] MPI startup(): Open 0 IB device: mlx5_0
[16] MPI startup(): Open 0 IB device: mlx5_0
[27] MPI startup(): Open 0 IB device: mlx5_0
[19] MPI startup(): Open 0 IB device: mlx5_0
[8] MPI startup(): Open 0 IB device: mlx5_0
[18] MPI startup(): Open 0 IB device: mlx5_0
[6] MPI startup(): Open 0 IB device: mlx5_0
[24] MPI startup(): Open 0 IB device: mlx5_0
[7] MPI startup(): Open 0 IB device: mlx5_0
[12] MPI startup(): Open 0 IB device: mlx5_0
[17] MPI startup(): Open 0 IB device: mlx5_0
[5] MPI startup(): Open 0 IB device: mlx5_0
[0] MPI startup(): Start 1 ports per adapter
[20] MPI startup(): Start 1 ports per adapter
[11] MPI startup(): Start 1 ports per adapter
[9] MPI startup(): Start 1 ports per adapter
[3] MPI startup(): Start 1 ports per adapter
[21] MPI startup(): Start 1 ports per adapter
[2] MPI startup(): Start 1 ports per adapter
[1] MPI startup(): Start 1 ports per adapter
[25] MPI startup(): Start 1 ports per adapter
[22] MPI startup(): Start 1 ports per adapter
[23] MPI startup(): Start 1 ports per adapter
[4] MPI startup(): Start 1 ports per adapter
[10] MPI startup(): Start 1 ports per adapter
[15] MPI startup(): Start 1 ports per adapter
[13] MPI startup(): Start 1 ports per adapter
[26] MPI startup(): Start 1 ports per adapter
[14] MPI startup(): Start 1 ports per adapter
[27] MPI startup(): Start 1 ports per adapter
[16] MPI startup(): Start 1 ports per adapter
[12] MPI startup(): Start 1 ports per adapter
[18] MPI startup(): Start 1 ports per adapter
[24] MPI startup(): Start 1 ports per adapter
[6] MPI startup(): Start 1 ports per adapter
[19] MPI startup(): Start 1 ports per adapter
[8] MPI startup(): Start 1 ports per adapter
[5] MPI startup(): Start 1 ports per adapter
[17] MPI startup(): Start 1 ports per adapter
[7] MPI startup(): Start 1 ports per adapter
[11] MPID_nem_ofacm_init(): Init
[0] MPID_nem_ofacm_init(): Init
[20] MPID_nem_ofacm_init(): Init
[9] MPID_nem_ofacm_init(): Init
[3] MPID_nem_ofacm_init(): Init
[21] MPID_nem_ofacm_init(): Init
[2] MPID_nem_ofacm_init(): Init
[1] MPID_nem_ofacm_init(): Init
[22] MPID_nem_ofacm_init(): Init
[25] MPID_nem_ofacm_init(): Init
[23] MPID_nem_ofacm_init(): Init
[11] MPI startup(): ofa data transfer mode
[0] MPI startup(): ofa data transfer mode
[20] MPI startup(): ofa data transfer mode
[4] MPID_nem_ofacm_init(): Init
[10] MPID_nem_ofacm_init(): Init
[26] MPID_nem_ofacm_init(): Init
[14] MPID_nem_ofacm_init(): Init
[15] MPID_nem_ofacm_init(): Init
[13] MPID_nem_ofacm_init(): Init
[27] MPID_nem_ofacm_init(): Init
[16] MPID_nem_ofacm_init(): Init
[12] MPID_nem_ofacm_init(): Init
[9] MPI startup(): ofa data transfer mode
[18] MPID_nem_ofacm_init(): Init
[3] MPI startup(): ofa data transfer mode
[8] MPID_nem_ofacm_init(): Init
[24] MPID_nem_ofacm_init(): Init
[19] MPID_nem_ofacm_init(): Init
[5] MPID_nem_ofacm_init(): Init
[21] MPI startup(): ofa data transfer mode
[17] MPID_nem_ofacm_init(): Init
[1] MPI startup(): ofa data transfer mode
[7] MPID_nem_ofacm_init(): Init
[2] MPI startup(): ofa data transfer mode
[6] MPID_nem_ofacm_init(): Init
[22] MPI startup(): ofa data transfer mode
[25] MPI startup(): ofa data transfer mode
[23] MPI startup(): ofa data transfer mode
[10] MPI startup(): ofa data transfer mode
[14] MPI startup(): ofa data transfer mode
[15] MPI startup(): ofa data transfer mode
[26] MPI startup(): ofa data transfer mode
[4] MPI startup(): ofa data transfer mode
[13] MPI startup(): ofa data transfer mode
[27] MPI startup(): ofa data transfer mode
[16] MPI startup(): ofa data transfer mode
[12] MPI startup(): ofa data transfer mode
[18] MPI startup(): ofa data transfer mode
[24] MPI startup(): ofa data transfer mode
[19] MPI startup(): ofa data transfer mode
[8] MPI startup(): ofa data transfer mode
[5] MPI startup(): ofa data transfer mode
[6] MPI startup(): ofa data transfer mode
[7] MPI startup(): ofa data transfer mode
[17] MPI startup(): ofa data transfer mode
Fatal error in MPI_Init: Other MPI error, error stack:
MPIR_Init_thread(805): fail failed
MPID_Init(1866)......: fail failed
MPIR_Comm_commit(711): fail failed
(unknown)(): Other MPI error
tamilalagan
Hello Xiang,
Can you please share your MPI environment variables or MPI launch command?
