Intel® MPI Library
2297 Discussions
ITAC error for multi-node tracing
mpiuser1
Hi Intel community,
We are trying to trace Quantum Espresso on multiple nodes with the Intel Trace Collector. It works on a single node, but for two nodes I get the following error:
[0] Intel(R) Trace Collector WARNING: STF Encoding Error: reducing unsigned 4-byte 0x10068 to unsigned 2-byte (_build/build_release_posix-x86_64_icl_18_gnutools_4.8/stf/stfencode.c:1844)
When we run the Trace Analyzer on the resulting stf file, it just hangs. We have tried the same scripts on benchmark applications and it does work.
Do you know what this error means?
Erica
AbhishekD_Intel
Hi Erica,
Thanks for connecting to us. As this issue is more related to ITAC, we are forwarding this issue to the concerned team. They will get back to you.
Warm Regards,
Abhishek
mpiuser1
Hi, thank you! Just checking in if there are any suggestions. Should I be posting on another board?
Mark_L_Intel
Could you provide STF file for 2-node case?
