Intel® MPI Library
ITC problems
Anonymous78
Clay,
I'm using IA-32(16 Dual-xeon processor cluster).
No, I don't think the problem is with the program.
This is the 'hello world' example and it run with
either MPICH2 and IMPI1 without ITC.
I also tried other more complex cases, and they fail
only when I use ITC.
I guess my problem
must be with the installation of ITC 6, although
I followed the instructution in the user guide.
Is there any simple check I can run to test the
installation?
Should I try v.5?
Thank you
Paolo
