Intel® MPI Library
2285 Discussions
Intel MPI 2019.5.281 not working with Intel Xeon Gold
Alchemist
Hi All,
I have trouble running mpirun (2019.5.281) on a node with Intel Xeon Gold processors. Running a simple 'mpirun hostname' command results in a single hydra_pmi_proxy process hanging endlessly and using 100% of core power without any error messages. Hostname is not returned.
The command below:
$ I_MPI_DEBUG=16 I_MPI_HYDRA_DEBUG=on FI_LOG_LEVEL=debug mpirun hostname
returns this and no other error messages:
[mpiexec@balerion] Launch arguments: /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin//hydra_bstrap_proxy --upstream-host balerion --upstream-port 43589 --pgid 0 --launcher ssh --launcher-number 0 --base-path /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/ --tree-width 16 --tree-level 1 --time-left -1 --collective-launch 1 --debug --proxy-id 0 --node-id 0 --subtree-size 1 --upstream-fd 7 /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin//hydra_pmi_proxy --usize -1 --auto-cleanup 1 --abort-signal 9
I tried setting some environmental variables as suggested for similar (but slightly different) problems, e.g. setting FI_PROVIDER=tcp, but it didn't help.
Exactly the same version of MPI works without issues on older Broadwell cpus (same cluster, same linux version) and even on a brand new Intel Xeon Silver node. I would really appreciate any clues and suggestions about the possible  origin of this problem and how it could be solved.
Thank you in advance!
Alchemist
Dear Santosh,
Thank you so much for taking time to help me. In the end, it turned out that our linux (Gentoo) kernel was compiled with incorrect settings, which hindered the communication between the processes. We missed something at the configuration step. Essentially, any version of Intel MPI didn't work for us, even though OpenMPI did. When tested on another linux distribution in live mode, Intel MPI started to work and we recompiled our Gentoo kernel with a functional configuration, which solved the problems. I still had to export FI_PROVIDER=tcp (or mlx) to enable proper running of programs using the MPI environment. We are still not sure what was the original source of the problem with the old kernel since the configuration contains many variables, packages and drivers.
Thanks once again!
SantoshY_Intel
We tried running the below command on a node with Intel(R) Xeon(R) Gold 6342 CPU using Intel MPI 2019.5.281 and it is working fine at our end.
 I_MPI_DEBUG=16 I_MPI_HYDRA_DEBUG=on FI_LOG_LEVEL=debug mpirun -bootstrap ssh hostname
output from my end:
Could you please try running a sample hello world program(attached below) using the below command and share with us the complete debug log?
mpiicc hello.c
I_MPI_DEBUG=16 I_MPI_HYDRA_DEBUG=on FI_LOG_LEVEL=debug mpirun -bootstrap ssh -n 2 ./a.out
Also, could you please provide the output for the below command?
fi_info
sample output from my end:
You can try any one of the providers from the fi_info output to set the value of FI_PROVIDER.  Usually, to run an MPI job on a single node, specifying FI_PROVIDER is not essential.
Example:
export FI_PROVIDER=verbs
Thanks & Regards,
Santosh
Alchemist
Thank you for your answer!
I do not have an up to date license for mpiicc and just intend to use runtime, so I cannot compile the hello.c code. However, hostname and any other command/program executed in the suggested way (e.g. date, echo etc.) doesn't produce any output and spawns the hanging hydra_pmi_proxy process. Every time, I need to abort mpirun with ctrl+c and then kill hydra_pmi_proxy.
I'm attaching a screenshot including the output of fi_info:
~ $ fi_info
provider: mlx;ofi_rxm
    fabric: mlx
    domain: mlx
    version: 1.0
    type: FI_EP_RDM
    protocol: FI_PROTO_RXM
provider: mlx
    fabric: mlx
    domain: mlx
    version: 1.5
    type: FI_EP_UNSPEC
    protocol: FI_PROTO_MLX
My node is equipped with the Intel(R) Xeon(R) Gold 6248R CPU.
Rafal
SantoshY_Intel
Since a simple "mpirun hostname" command is failing, there might be some installation (or) Intel MPI setup issues at your end.
We recommend you try re-installing the existing Intel MPI library and try again (or) you can upgrade to the latest Intel MPI Library which is available as a standalone product and as part of the Intel® oneAPI HPC Toolkit.
For downloading HPC Toolkit refer to the below link:
https://www.intel.com/content/www/us/en/developer/tools/oneapi/hpc-toolkit-download.html
Refer to the below link on how to start with Intel MPI Library:
https://www.intel.com/content/www/us/en/develop/documentation/get-started-with-mpi-for-linux/top.html
Thanks & Regards,
Santosh
Alchemist
Dear Santosh,
Thanks once again!
SantoshY_Intel
Glad to know that your issue is resolved. Thanks for sharing the solution with us. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Santosh
