Intel® MPI Library
2285 Discussions
Intel-MPI 2021: Which TCP ports range is used by default?
Olivier-Fr
I was not able to find this information into the user documentation...
Could you please share the default TCP ports range used by Intel-MPI 2021?
Many thanks in advance.
Olivier
ShivaniK_Intel
We are working on it and will get back to you.
Thanks & Regards
Shivani
ShivaniK_Intel
Thank you for your patience.
There are no default port ranges, you can use "any" port, which is available. But you can specify which ports to use by the I_MPI_PORT_RANGE variable.
Thanks & Regards
Shivani
ShivaniK_Intel
As we did not hear back from you could you please respond to my previous post?
Thanks & Regards
Shivani
Olivier-Fr
Hello Shivani,
Indeed, I apologize for my late feedback on this topic;
After internal coordination with Security guys, we have been able to monitor the ports usage and define the appropriate firewall rules, in conjuction with I_MPI_PORT_RANGE, and to have a "clean" configuration for Intel-MPI usage.
Thanks for your help!
Olivier
ShivaniK_Intel
Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards
Shivani
